I have switch case in which I want to compare different lengths of prefixes:
bit [7:0] compare
case (compare)
8'b000_0_0101 : do A
8'b010_0_0101 : do B
8'b001_1_0??? : do C
default : do D
endcase
my problems is in the last case before the default, every combination starts with 5’b001_1_0 should hit the third case but using questions mark in the suffix doesn’t work and it goes to the default, is there any way to make it work?
Thanks!
In reply to moshiko:
You want to use casez statement instead of a plain case statement. “casez” uses a convention that a bit that is “z” is a don’t-care (the ? character in a numeric literal is the same as a z).
Nevermind,
I found the solution, replacing case with casex
Thanks!
Avoid using casex. When using 4-state expressions, an X bit in the case expression becomes a don’t care the same in the case item.
Use casez instead, even better is using case () inside. The latter uses the asymmetric equality operator ==? so that only X or Z in the case item become don’t cares.
