Do we need get_full_name() in sequence item creation? If so, why?
Which of the below is correct?
task body();
        apb_rw rw_trans;
        repeat(10) begin
            rw_trans  = apb_rw::type_id::create(.name("rw_trans"),.contxt(get_full_name()));
            start_item(rw_trans);
            assert(rw_trans.randomize());
            finish_item(rw_trans);
task body();
        apb_rw rw_trans;
        repeat(10) begin
            rw_trans  = apb_rw::type_id::create("rw_trans");
Why are .name and .contxt used? Is it necessary?
In reply to sriharifoxtrot:
This should have been a compiler error. The context is supposed to be a uvm_component not a string. And the contxt argument is only used when creating other uvm_components to create the component hierarchy.
The name argument is used to build a sequence call chain, similar to the component hierarchy.It’s used for reporting a debugging.
Since this is a useful pattern in sequences:
item = item_type::type_id::create( "item", null, get_full_name() );
Is there some reason that this function:
static function T uvm_object_registry #(T,Tname)::create (
   	string 	        name	 = 	"",
   	uvm_component   parent	 = 	null,
   	string          contxt	 = 	""
Isn’t defined like this:
   	string 	        name	 = 	"",
   	uvm_object      parent	 = 	null, // <-- now works for both sequences and components
   	string          contxt	 = 	""
Then the pattern:
obj = obj_type::type_id::create( "obj", this );
Would work in both components and sequences. Maybe the implementation would need to perform a test cast so it knows whether the parent is a component or a sequence, but I don’t see why this wouldn’t work. This would even be a backwards compatible change to the UVM library.
-Ryan
I believe adding get_full_name() in create will give the additional functionality of using set_inst_override_by_type. without get_full_name() this is not possible OR you move to `uvm_create
