Ratio of A and B should be 1/1.5/3 . Why the below constraint isn’t working as expected?
class try;
rand int A, B;
constraint value_range {
A inside {[0:200]};
B inside {[0:200]}; }
constraint ratio_constraint {
A / B inside {1, 3}; }
module mod ();
try obj = new;
obj.randomize();
$display("A = %0d, B = %0d", obj.A, obj.B);
$finish;
Thanks.
In reply to verif_guy12:
It would help to show differences in results between what you are expecting and what you are seeing.
One problem is you may have is doing integer division. You need to scale the numbers up.
class try;
rand int A, B;
A inside {[0:200]};
B inside {[1:200]}; } // prevent divide by 0
A*1000/ B inside {1000, 3000}; }
module mod ();
initial repeat (20) begin
static try obj = new;
assert(obj.randomize());
Thank you Dave, This helps.
But A and B are actually 2 clock frequencies and with above code change I am getting A = 12000 , B = 3999
A/B = 3.000750187
Expectation is that ratio of these two frequencies has to be exact 1,1.5,2,3,4
A inside {[3000:12000]}
B inside {[2550:4000]}
Would appreciate any suggestions.
A inside {[3000:12000]};
B inside {[2550:4000]};
(A * 1000) % B == 0; //New
(A * 1000) / B inside {1000, 1500, 2000, 3000, 4000};
This additional constraint worked for me.
