Hi All,
I was trying to model dynamic repeat using a user-defined sequence.
Here is my attempt :: lf_edalink
LRM 16.12.22 Nondegeneracy states
Any sequence that is used as a property shall be nondegenerate and shall not admit any empty match.
I observe that one tool treats the consequent as illegal whereas as per my understanding the consequent is legal.
Refer the right side ( design.sv ) in lf_edalink where I have noted my interpretation of the consequent
[Q1] Just wanted to check with forum moderators if my understanding is correct
I tried a simplified version of the consequent in lf_edalink2 where the output matches my understanding
I sent this for the next 1800 version. Did you see it?
SVA: 1800’2023 Degeneracy Issue to Hopefully be Addressed in 1800’2028
When faced with degenerate sequences, 1800’2023 is unclear on what a simulator should do, particularly in situations resulting from parameter substitution that creates a degenerate sequence. In that situation, it would be undesirable to have to rewrite the code to get to a successful compilation. Existing tools differ in their interpretation of degenerate sequences - some report it as a degenerate situation, some issue a warning, and some proceed with the simulation.
This linked document identifies the sections in the LRM that define degeneracy and highlights cases that pose challenges for users and tool vendors. Additionally, it proposes solutions for the next revision of the LRM.
Ben, in collaboration with Ed Cerny
5) Never be matched, no match can exist
(ii) a ##1 1’b0-- logically impossible- a followed by false
case (5.ii) is attributed to a false logical value resulting from parameter substitution. In both scenarios, if utilized in a property, they would lead to an unsatisfied property
I am not clear on “attributed to a false logical value resulting from parameter substitution”
I found a thread related to using hard zero in concurrent assertion where Dave commented
“In the hard_zero assertion, the (0) does not get evaluated until run-time”
(2) In the original post the irony is that the same tool ( VCS ) that throws compilation error for edalink treats ‘sva2’ in edalink2 as legal.
It seems like a tool issue/limitation as in both cases the consequent is equivalent to ( 1'b0 ) or ( Non_Degenerate_Sequence ) i.e ( Non_Degenerate_Sequence )
As consequent :: ( 1'b0 ) or ( Non_Degenerate_Sequence )doesn’t violate the following LRM quote
I am of the opinion that consequent is legal in edalink
Please correct me if I am wrong in my interpretation.
[YOU] I am not clear on “attributed to a false logical value resulting from parameter substitution”
[Ben] Example or param substitution: Edit code - EDA Playground
module m #(parameter K = 1) // parameter with default value
(input bit clk, a, b);
ap_impossible: assert property(@(posedge clk) a |-> b ##1 K);
bit a=1, b=1, clk;
always #1 clk=!clk;
m #(0) m1 (.clk(clk), .a(a), .b(b)); // override parameter value
initial #100 $finish;
[YOU] I found a thread related to using hard zero in concurrent assertion where Dave commented
( 1’b0 ) or ( Non_Degenerate_Sequence ) i.e ( Non_Degenerate_Sequence )
As consequent :: ( 1’b0 ) or ( Non_Degenerate_Sequence ) doesn’t violate the following LRM quote
I am of the opinion that consequent is legal in edalink [Ben]
1800 says a) Any sequence that is used as a property shall be nondegenerate and shall not admit any empty match.
You are addressing case 3 in the pdf:
Empty and non-empty matches
a[*0:1] – empty and a possible non-empty match
It does admit an empty match.
This is why we wrote this potential change to 1800…
Ben ,
There is a difference between the following sequences when used as consequent
(1) a[*0:1] // Admits ‘Empty match’ via a[*0]
(2) a[*0:1] ##0 1 // Admits ‘No match’ ( 1’b0 ) via ( a[*0] ##0 1 )
(1) is illegal as it violates the LRM quote since the consequent admits empty match via a[*0]
(2) is legal as consequent since it doesn’t violate the above LRM quote
The same can be comfirmed in edalink2where ‘sva1’ is illegal and ‘sva2’ is legal
In my original post the consequent inedalinkresembles (2) and not (1)
VCS treats ‘sva2’ in eda2 legal whereas it treats consequent in eda as illegal
In both cases a sub-sequence in the consequent is ( empty_seq ##0 seq ) i.e it admits ‘No match’ ( 1’b0 )
Hence I believe the compilation error observed in edalinkis a tool limitation/issue as the consequent doesn’t admit any empty match.
a |-> b[*0:1] ##0 c; // is equivalent to
a |-> (b[*0] ##0 c) or (b[*1] ##0 c); // is equivalent to
a |-> 0 or (b[*1] ##0 c); // is equivalent to
a |-> b[*1] ##0 c;
The above consequent is considered legal ( although a sub-seq. admits “No match” ) as it ::
(1) Doesn’t admit any empty match
(2) Admits non-empty match
On the same note, sub-sequence((count == 0) ##0 (seq[*0] ##0 seq3)) in edalink
is equivalent to ( seq_expr ##0 (1'b0) ) i.e “No Match” ( 1’b0 )
(b[*0] ##0 c) // is (empty ##0 c) and that is degenerate
// it is not (0 ##0 c). We talked about degeneracy rues
(count == 0) is legal and can evaluate to true or false depending on the value of count. That is different than
a |-> 0 ##1 1; // it is degenrate by construction
Since we are not supposed to discuss tool related issues, I am curious to know From a strict LRM perspective is the consequent sequence ‘abd_dynamic_repeat’ in edalink legal ?
As per my understanding it doesn’t violate the following LRM quote
The consequent is essentially :: sub_seq1 or sub_seq2
