Hello All,
Can someone please explain what is the clear cut difference between uvm_reg_sequence and uvm_sequence. I have tested a sequence extending from either of these two , but the behavior I got was the same from both of them.
Thanks In Advance.
Hello All,
Thanks In Advance.
In reply to prashantk:
You can see this in the UVM Reference Manual, delivered with the UVM class library.
Shortly to summarize:
(1) extension of uvm_sequence
(2) adds the write read API to uvm_sequence.
