Difference between assume and assert statement?
I do understand assert(property_name) will check for failurs in property or sequence and
Cover(property_name) will check for coverage in property or sequence. What is the actual use of assume statement?
The distinction is mainly for formal tools. An assume directive is the same as an assert in simulation. A formal tool uses an assume directive as a constraint depending on what level in the hierarchy it is placed.
thansks for ur reply. Can u please elaborate on the same?
Rakesh
In reply to rakeeee:
From SystemVerilog Assertions Handbook, 3rd Edition
See http://systemverilog.us/assert_assume_restrict.pdf
As a methodology note, we suggest you use “assume” if you are writing a property solely based on design inputs. If it is on outputs/internal signals/mix, then use assert.
And yes, we delve into details on this in our SVA book (www.systemverilog.us)
Regards
Ajeetha, CVC
