Difference between ' ##0 ' and ' && ' in Assertions
Hi ,
I was trying scenarios using ’ ##0 ’ and ’ && ’ interchangeably .
Consider the following property expression :
  @( posedge clk )  a |=> $rose( b )  ##0 $rose( c );
An alternative to the above using logical operator ’ && ’ would be ::
  @( posedge clk )  a |=> ( $rose( b ) &&  $rose( c ) ) ;
Now if the signals ’ b ’ and ’ c ’ are to be asserted after unknown clocks , I would write property expression as :
  @( posedge clk )  a |-> ##[1:$] ( $rose( b ) ##0 $rose( c ) );
Alternative using ’ && ’ would be :
  @( posedge clk )  a |-> ##[1:$] ( $rose( b ) && $rose( c ) );
A better simulation efficient solution would be :
  @( posedge clk )  a |=> ( $rose( b ) && $rose( c ) ) [->1] ;  // Could be [=1]  as  well in this case  !!
However on writing :
  @( posedge clk )  a |=> ( $rose( b ) ##0 $rose( c ) ) [->1] ;  // Compilation Error !!
Why is it ##0 is considered Illegal using go-to operator ?
In reply to Have_A_Doubt:
It is a syntactical restriction. The left operand of the goto operator [->] must be a boolean expression (or distribution). ##0 is not boolean operator. Even though some sequence expression degenerate into boolean expressions, they are not syntactically boolean expressions.
One more thing to add on Dave’s reply:
I read the ##0 as the start of a new sequence that starts in the same time
step as the end point of the preceding sequence. Thus,
@( posedge clk ) a |=> $rose(b) ##0 $rose( c );
It’s a different connotation than the logical && that represents combinational logic.
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
Hi Ben ,
I read the ##0 as the start of a new sequence that starts in the same time step as the end point of the preceding sequence.
Do you mean to say that go-to repetition can only be used with a sequence and not with a concatenation of 2 sequences using ##0 ?
Hi Ben ,
Do you mean to say that go-to repetition can only be used with a sequence and not concatenation of 2 sequences using ##0 ?
The syntax for the goto is Boolean [> n].
b[->1] is equivalent to: !b[*0:] ##1 b b[->2] is equivalent to: !b[*0:] ##1 b ##1 !b[*0:$] ##1 b
b[->2] is equivalent to b[>1] ##0 b[->1]
