Defining array's range according to enumerated type attributes
Hi.
I have an enumerated type e.g.
typedef enum logic[1:0] {
        FIRST,
        SECOND,
        THIRD,
        LAST
    } my_type;
I want to define one-hot vector (say a selector) accordingly without actually using the enumarated values.
I use the following method:
parameter my_type auxPrm = FIRST;
typedef logic [auxPrm.last():auxPrm.first()] one_hot_sel_vec_type;
one_hot_sel_vec_type one_hot_sel_vec;
Now, xilinx’s VIVADO is ok with this writing but synopsys’s synplify asserts an error:
“range’s bounds are not constant” referring to the “one_hot_sel_vec_type” definition which is weird because I intentionally defined a parameter “auxPrm” which is constant.
My question is then,
Am I wrong in my writing method?
Is there any other “right/standard” way of achieving the same result?
Thanks!
Itay.
In reply to itay yehekzel karo:
You have hit a tool specific issue. The only workaround is using the enum labels directly.
Thanks.
You mean its synplify’s error? the way of writing is allowed in the verilog standard?
