Hi Forum,
As a newbie I was trying following code on edaplayground
Class send_txn1 inherits non-virtual function activate and overrides virtual function do_activate
(1) Why does the overridden task do_activate get called and not the do_activate API in base class ?
(2) Wouldn’t the call to activate call the task defined in base class ?
(3) What does inheritance actually mean ? I understand that extended classes have access to inherited APIs / properties
Would the activate task implicitly be written as part of extended class ? i.e Is it equivalent to re-write activate in extended class ?
