Data stable throughout a clock cycle // NO GLITCH
This is a response to a question. Generally, this is not done, but the solution is interesting and a bit challenging.
SystemVerilog.us/fv/glitchclk.sv
	bit clk, a, w;
    event e, e0, e1;
	initial forever #10 clk=!clk;
    task automatic glitch();
        bit err=0;
            fork1: begin
                -> e0;
                @(posedge clk);
                disable fork2;
            fork2: begin
                @(a);
                disable fork1;
                err=1;
                -> e1;
        join_any
        // $display("%t @join %t, err=%b", $realtime, $realtime, err);
        if(err) begin
              a_glitch: assert (!err)  else $display("%t ERROR: Glitch in a", $realtime);
                -> e;
    always @(a)  glitch();
	always  @(posedge clk)  begin
	   automatic bit va, vd;
	   if (!randomize(va, vd)  with
	   		{ va dist {1'b1:=2, 1'b0:=1};
	   		  vd dist {1'b1:=1, 1'b0:=2};
        if(vd) begin
            #2 a <= !va;
            #1 a <= va;
        else a <= va;
  3. Papers:
A linkedIn user provided an alternate code to check that the clock half-cycles are within specs with no glitches. It is another approach.
I added 2 assertions to the code; you obviously appreciate the reduction in code when using SVA.
let halfp = clk_period_half * 1ns;
property p_clk0;
  realtime t;
  @(negedge clk) !pause |-> (1, t=$realtime) ##1 @(posedge clk) $realtime-t == halfp;
ap_clk0: assert property(p_clk0);
property p_clk1;
    realtime t;
    @(posedge clk) !pause |-> (1, t=$realtime) ##1 @(negedge clk) $realtime-t == halfp;
ap_clk1: assert property(p_clk1);
http://SystemVerilog.us/fv/clk_chk.sv
** Error: [POS_EDGE_CHECK] transition expected 5 , observed 1
Time: 96 ns Scope: test.i_checker File: C:/ben_play/clk_chk.sv Line: 52
** Error: Assertion error.
Time: 96 ns Started: 95 ns Scope: test.i_checker.ap_clk0 File: C:/ben_play/clk_chk.sv Line: 11 Expr: $realtime()-t==511ns
Local vars : t = 95
** Error: [NEG_EDGE_CHECK] transition expected 5 , observed 1
Time: 147 ns Scope: test.i_checker File: C:/ben_play/clk_chk.sv Line: 70
Time: 147 ns Started: 146 ns Scope: test.i_checker.ap_clk1 File: C:/ben_play/clk_chk.sv Line: 17 Expr: $realtime()-t==511ns
Local vars : t = 146
  1. SVA Package: Dynamic and range delays and repeats https://rb.gy/a89jlh
  3. Papers:
