Cyclic randomization behavior without 'randc' keyword
Can anyone give an idea on how to bring cyclic randomization without using randc keyword and queue/array as for reference
Common methods for genearting cyclic randomization is
  1. Using randc keyword
  2. using a queue/array, checking whether element to be randomized has values in queue/array and pushing the newely randomized value into the array in post_randomize()
I am trying to get the cyclic randomization behavior with methods not mentioned above
In reply to bachan21:
class abc;
  rand logic[2:0] a;
  int saved[$];
  constraint c1 { !(a inside saved);}
    saved.push_back(a);
    if(saved.size == 2**3)begin
      saved = {};
module abc;
  abc a1;
    a1 = new();
    repeat(8)begin
    a1.randomize();
    $display(a1.a);
In reply to yourcheers:
I am trying to implement my intention without post_randomize or unique keyword.
Any further thoughts?
P.S. Kudos to your clean coding. Thumbs up
[1] Try the same logic in pre_randomize()
[2] Have a Simple Counter which increments in pre_randomize()
There is absolutely no way of replicaiting the functionality of the randc modifier without using an array of used or unused values. If there are any constraints on the random variable, you have no idea how many values need to be generated before you need to restart the cycle.
If you are looking for a synthesizable cycle of noncontiguous values, you might want to study linear feedback shift registers (LFSRs).
It might help to explain where your requirements are coming from if not just an interview question.
Thanks Dave
I wanted to see if there is any possibility for this problem than the conventional methods for cyclic randomization
