Eda playground link is dff_vip_nocfg - EDA Playground
Could you please help in resolving this error.
TimeScale is 1 ns / 10 ps
Error-[XMRE] Cross-module reference resolution error
driver.sv, 55
Error found while trying to resolve cross-module reference.
token ‘vif’. Originating package ‘test_pkg’.
Source info: @(posedge vif.clk) ;
driver.sv, 56
Source info: if (!vif.rst) begin
vif.q <= d_trans_h.d;
vif.q <= 0;
And 1 more error in scoreboard
Error-[TFAFTC] Too few arguments to function/task call
scoreboard.sv, 57
uvm_pkg, “this.compare()”
The above function/task call is not done with sufficient arguments
Hi
Your code in the mentioned eda link is working. What was the mistake from my code. Could you please elaborate and I did not see any uvm_info print after compiling your code because run_test is not called is my conclusion correct?
You are completely right. And there are more weaknesses in the code provided which are tolerated by VCS. You should clean-up your code and insert diagnostic messages to see the progress when starting the simulation.
The key problem is you do not constructt your analysis ports/exports in the monitors and the scoreboard.
See here:
Hi I have modified the code and added uvm_info statements but when I run this code no other uvm_info is printed except uvm_error which is defined in scoreboard. Could you please tell me what am I missing?
Can you please respond to my email christoph@christoph-suehnel.de
I have downloaded your example to work locally.
I can send you my solution which still needs some adoption wrt to the monitor handling.
