Hello,
I want to make a cross cover of something that supposed to be enabled, with 3 possible events.
So let’s say I have the following cover points:
cp_B : item.flag {
bins B_enable = {EN};
cp_events : item.events {
bins cp_event_number[3] = {[3:5};
What I want is to have a coverage for B at 3, B at 4, B at 5.
Currently, I tried the following:
cp_BxEvents : cp_B, cp_events {
bins BxEvent = binsof(cp_B.B_enable) && binsof(cp_events.cp_event_number);
ignore_bins ...
Which creates only 1 coverpoint and not all 3.
Trying to do one of the following:
bins BxEvent[] = ...
bins BxEvent[3] = ...
bins BxEvent = ... && binsof(cp_events.cp_event_number[]);
bins BxEvent = ... && binsof(cp_events.cp_event_number[3]);
Generates an error.
So, how should I write the cross coverage bins?
Thank you
In reply to Ariel Elliassi:
Use Select Expression when defining Cross bins ::
binsof( cp_label ) intersect { <values> } ;
!binsof( cp_label ) intersect { <values> } ;
If you want to ignore cross bins with item.events == 4 and 5
cp_BxEvents: cross cp_B , cp_events
bins BxEvent3 = binsof( cp_events ) intersect { 3 } ; // < EN , 3 >
ignore_bins igcross = !binsof( cp_events ) intersect { 3 } ; // < EN , 4 >
// < EN , 5 >
(b) If you want user-defined cross bins for item.events == 4 and 5
bins BxEvent4 = binsof( cp_events ) intersect { 4 } ; // < EN , 4 >
bins BxEvent5 = binsof( cp_events ) intersect { 5 } ; // < EN , 5 >
In reply to MICRO_91:
Thank you, that’s helpful as well.
I was wondering on a way to do “bins BxEvents” that will generate 3 bins in the same way as this:
bins array[3] = {[3:5]};
Will generate 3 cover points, one for each value, from 1 line.
LRM Syntax 19-4 defines ::
bins_keyword bin_identifier = select_expression [ iff ( expression ) ]
This means only a Singular bin ( bin_identifier ) can be defined within cross .
Multiple bins ( using [ ] ) , Fixed ( bins array[3] ) are Illegal .
I see, that’s what I suspected.
So basically, there’s no way except for writing 3 separate bins for each events, and making 3 bins inside the cross for each <EN,event_number>.
Thank you
You need not define the 3 cross bins .
On writing ::
cp_BxEvents: cross cp_B , cp_events ; // Creates 3 cross bins automatically
As coverpoints ’ cp_B ’ and ’ cp_events ’ have 1 bin and 3 bins respectively .
Cross ’ cp_BxEvents ’ has 1 x 3 i.e 3 cross bins
