what is 3-byte queue ?
Create a 3-byte queue and initialize it with 2, −1, and 127
Print out the sum of the queue in the decimal radix
i think this is the correct syntaxbyte queue[$:2];
In reply to Prudhvi Krishna :
that syntax declares an empty queue with a maximum size of two elements.
A “3-byte queue” could mean a number of things. Most likely it means to clear a queue of bytes with three elements initially.
byte queue [$] = {2, −1, 127};
module tb;
//Create a 3-byte queue and initialize it with 2, −1, and 127
// Print out the sum of the queue in the decimal radix
byte q [$] = '{2,-1,127};
int sum;
for (int i=0;i<$size(q);i++) sum = sum + q[i];
$display ("sum is %d",sum);
i think that 3 byte queue is a bounded queue with 3 bytes
