I am trying to collect coverage on the sequence of attributes on transaction objects arriving in, say, a uvm_subscriber object
For example, if the transaction has a variable called id, and I would like to cover the sequence where the ID for the transaction objects coming is 0 -> 0 -> 1 -> 0, I could write something like:
class my_subscriber extends uvm_subscriber;
covergroup cg_seq with function sample(bit id);
seq0: coverpoint (id) {
bins seq = (0 => 0 => 1 => 0);
endgroup
virtual function void write (my_txn txn);
cg_seq.sample (txn.id);
endclass : my_subscriber
This works reasonably well.
However, for more complex sequence of IDs, I hit the limit of what a coverpoint sequence can do. For example, this won’t compile because of the $:
seq1: coverpoint (id) {
bins seq = (0 => 0 => 1[*8:$] => 0);
endgroup
It certainly seems that I need to use cover property instead, but I am unsure how to do this for transaction level coverage? There is no equivalent sample function for property blocks, as far as I am aware?
I have several workarounds, including writing the code to cover this in procedural code, but was wondering if anyone else had different ideas they’ve used before?
Thanks!
