Copy function for Parameterized Class
I am struggling to write a typical copy function of a parameterized class.
class seq_item #(parameter int AWIDTH=10, parameter int DWIDTH=16);
  rand bit[AWIDTH-1 :0] addr;
  rand bit[DWIDTH-1 :0] data;
  virtual function seq_item copy(seq_item to=null);
    seq_item tmp;
    if (to == null) tmp = new();
    else tmp = to;
    tmp.addr = this.addr;
    tmp.data = this.data;
    return tmp;
If I call the copy function from a object which is created by overriding the default seq_item parameter values, it causes a compilation error.
In reply to mussoi:
You want to make sure that you use the parameterized version of your class in the copy function:
  typedef seq_item#(AWIDTH,DWIDTH) seq_item_t;
  virtual function seq_item_t copy(seq_item_t to=null);
    seq_item_t tmp;
    else tmp = to;
    return tmp;
