Controller FSM Outputs are all don't care values
I’m trying to design the controller FSM for the MIPS multicycle CPU. My first two states output the correct result. But after that they are all don’t care values and I don’t know why. The op(opcode) and funct are instruction parameters. The zero signal is an output signal of the ALU that is 1 if the ALU result is 0. In my testbench, I’m only testing only the beq insruction in my function.
CODE:
module controller(input logic clk, reset,
input logic [5:0] op, funct,
input logic zero,
output logic pcen, memwrite, irwrite, regwrite,
output logic alusrca, iord, memtoreg, regdst,
output logic [1:0] alusrcb, pcsrc,
output logic [2:0] alucontrol);
logic [1:0] aluop;
logic branch, pcwrite;
// Main Decoder and ALU Decoder subunits.
	maindec md(clk, reset, op,
	pcwrite, memwrite, irwrite, regwrite,
	alusrca, branch, iord, memtoreg, regdst,
	alusrcb, pcsrc, aluop);
	aludec ad(funct, aluop, alucontrol);
// ADD CODE HERE
// Add combinational logic (i.e. an assign statement)
// to produce the PCEn signal (pcen) from the branch,
// zero, and pcwrite signals
	assign pcen=(branch && zero) ||(pcwrite);
//MAINDEC:
module maindec(input logic clk, reset,
output logic pcwrite, memwrite, irwrite, regwrite,
output logic alusrca, branch, iord, memtoreg, regdst,
output logic [1:0] aluop);
parameter FETCH = 4'b0000; // State 0
parameter DECODE = 4'b0001; // State 1
parameter MEMADR = 4'b0010; // State 2
parameter MEMRD = 4'b0011; // State 3
parameter MEMWB = 4'b0100; // State 4
parameter MEMWR = 4'b0101; // State 5
parameter RTYPEEX = 4'b0110; // State 6
parameter RTYPEWB = 4'b0111; // State 7
parameter BEQEX = 4'b1000; // State 8
parameter ADDIEX = 4'b1001; // State 9
parameter ADDIWB = 4'b1010; // state 10
parameter JEX = 4'b1011; // State 11
parameter LW = 6'b100011; // Opcode for lw
parameter SW = 6'b101011; // Opcode for sw
parameter RTYPE = 6'b000000; // Opcode for R-type
parameter BEQ = 6'b000100; // Opcode for beq
parameter ADDI = 6'b001000; // Opcode for addi
parameter J = 6'b000010; // Opcode for j
	logic [3:0] state, nextstate;
	logic [14:0] controls;
// state register
	always_ff @(posedge clk or posedge reset)
	if(reset) state <= FETCH;
	else state <= nextstate;
// ADD CODE HERE
// Finish entering the next state logic below. The first
// two states, FETCH and DECODE, have been completed for you.
// next state logic
	always_comb
	case(state)
	FETCH: nextstate = DECODE;
	DECODE: case(op)
	LW: nextstate = MEMADR;
	SW: nextstate = MEMADR;
	RTYPE: nextstate = RTYPEEX;
	BEQ: nextstate = BEQEX;
	ADDI: nextstate = ADDIEX;
	J: nextstate = JEX;
	default: nextstate = 4'bx; // should never happen
	endcase
// Add code here
	MEMADR: case(op)
	LW: nextstate=MEMRD;
	SW: nextstate= MEMWR;
	default: nextstate= 4'bx;
	endcase
	MEMRD: nextstate= MEMWB;
	MEMWB: nextstate= FETCH;
	MEMWR: nextstate=FETCH;
	RTYPEEX: nextstate= RTYPEWB;
	RTYPEWB: nextstate= FETCH;
	BEQEX: nextstate= FETCH;
	ADDIEX: nextstate= ADDIWB;
	ADDIWB: nextstate= FETCH ;
	JEX: nextstate= FETCH;
	endcase
// output logic
	assign {pcwrite, memwrite, irwrite, regwrite,
	alusrcb, pcsrc, aluop} = controls;
// ADD CODE HERE
// Finish entering the output logic below. The
// output logic for the first two states, S0 and S1,
// have been completed for you.
	always_comb
	case(state)
	FETCH: controls = 15'h5010;
	DECODE: controls = 15'h0030;
	// your code goes here
	MEMADR: controls = 15'h0420;
	MEMRD: controls = 15'h0520;
	MEMWB: controls = 15'h0da0;
	MEMWR: controls = 15'h25a0;
	RTYPEEX: controls = 15'h0582;
	RTYPEWB: controls = 15'h0d42;
		BEQEX: controls = 15'h0745;
	ADDIEX: controls = 15'h0564;
	ADDIWB: controls = 15'h0c24;
	JEX: controls = 15'h4428;
	default: controls = 15'hxxxx; // should never happen
	endcase
// ALUDEC:
module aludec(input logic [5:0] funct,
input logic [1:0] aluop,
// ADD CODE HERE
// Complete the design for the ALU Decoder.
// Your design goes here. Remember that this is a combinational
// module.
// Remember that you may also reuse any code from previous labs.
always_comb
    case(aluop)
      2'b00: alucontrol = 3'b010;  // add
      2'b01: alucontrol = 3'b110;  // sub
      2'b11: alucontrol = 3'b001;  // OR
      default: case(funct)          // RTYPE
          6'b100000: alucontrol = 3'b010; // ADD
          6'b100010: alucontrol = 3'b110; // SUB
          6'b100100: alucontrol = 3'b000; // AND
          6'b100101: alucontrol = 3'b001; // OR
          6'b101010: alucontrol = 3'b111; // SLT
          default:   alucontrol = 3'bxxx; // ???
        endcase
    endcase
TESTBENCH:
module testbench();
logic clk,reset,zero,pcen;
logic [5:0] op,funct;
logic [15:0] controls;
logic [3:0] state;
logic [2:0] alucontrol;
logic [1:0] aluop;
logic  memwrite, irwrite, regwrite,alusrca, iord, memtoreg, regdst;
logic [1:0] alusrcb, pcsrc;
controller dut(.clk(clk),.reset(reset),.op(op),.funct(funct),.zero(zero),.alucontrol(alucontrol),.pcen(pcen)
,.memwrite(memwrite),.irwrite(irwrite),.regwrite(regwrite),.alusrca(alusrca)
,.iord(iord),.memtoreg(memtoreg),.regdst(regdst),.alusrcb(alusrcb),.pcsrc(pcsrc));
always
      clk = 1; # 5; clk = 0; # 5;
initial
reset=1;#10;
reset=0;#10;
op=000100;
funct=000000;
zero=1;#10;
change your testbench code to
op=6’b000100;
The value of ‘op’ being passed into the DUT was being treated as a decimal number
ie 100
which when you convert to binary is 1100100
but since op is defined as [5:0] then the MSB got dropped
So the value of op inside the DUT was seen as ‘100100’ which is not a valid state
In reply to graeme_jessiman:
Yes, that did make the signals display properly. However, I instantiated the maindec module in my testbench because I wanted to output the state and controls signals. But they are still don’t care values after adding the change you suggested.How do I make them to work?
My new testbench is:
module testbench();
		logic clk, reset, zero, pcen,pcwrite,branch;
		logic [5:0]  op, funct;
		logic [3:0]  state;
		logic [1:0]  aluop;
		controller dut(.clk(clk), .reset(reset), .op(op), .funct(funct)
		, .zero(zero), .alucontrol(alucontrol), .pcen(pcen)
		, .memwrite(memwrite), .irwrite(irwrite), .regwrite(regwrite)
		, .alusrca(alusrca), .iord(iord), .memtoreg(memtoreg)
		, .regdst(regdst) , .alusrcb(alusrcb), .pcsrc(pcsrc));
		maindec dut_1(.clk(clk), .reset(reset), .op(op),.pcwrite(pcwrite),.memwrite(memwrite), .irwrite(irwrite), .regwrite(regwrite)
		,.alusrca(alusrca),.branch(branch),.iord(iord),.memtoreg(memtoreg), .regdst(regdst) , .alusrcb(alusrcb), .pcsrc(pcsrc),.aluop(aluop));
		always
			clk = 1; # 5;
			clk = 0; # 5;
		initial
		reset = 1; #10;
		reset = 0;
		op = 	6'b000100;
		funct= 	6'b100010;
		zero = 1;  #10;
I modified the order of the assignments… .as op was not getting any value until after the #10 had executed 10 time units.
i.e.
initial
  op=6'b000100;
  funct=6'b100010
  reset=1;#10;
  reset=0;#10;
  zero=1;#10;
This simulates and I see state & next_state change every clock cycle
I tried this code. However, state and controls always stay as don’t care values. Also, for some reason, I don’t see nextstate listed on my waveform screen. The code I used was:
CODE:
						input logic zero,
	logic [1:0] aluop;
	 // ADD CODE HERE
	assign pcen = (branch && zero) || (pcwrite);
//MAINDEC:
		// state register
			// ADD CODE HERE
			// next state logic
			always_comb
				case(state)
					DECODE:
						case(op)
							J: 			nextstate = JEX;
						endcase
					// Add code here
					MEMADR:
						case(op)
							LW: nextstate = MEMRD;
							SW: nextstate = MEMWR;
						endcase
					MEMRD: 	nextstate = MEMWB;
					MEMWB: 	nextstate = FETCH;
					MEMWR: 	nextstate = FETCH;
					RTYPEEX: nextstate = RTYPEWB;
					RTYPEWB: nextstate = FETCH;
					BEQEX: 	nextstate = FETCH;
					ADDIEX: 	nextstate = ADDIWB;
					ADDIWB: 	nextstate = FETCH ;
					JEX: 		nextstate = FETCH;
				endcase
		// output logic
		// ADD CODE HERE
		always_comb
			case(state)
			endcase
// ALUDEC:
				// ADD CODE HERE
				// module.
				always_comb
					 case(aluop)
						default:
								endcase
					 endcase
TESTBENCH:
module testbench();
		logic [3:0]  state;
		logic [1:0]  aluop;
		always
			clk = 1; # 5;
			clk = 0; # 5;
		initial
		op=6'b000100;
  		funct=6'b100010;
  		reset=1;#10;
  		reset=0;#10;
  		zero=1;#10;
		reset = 1; #10;
		reset = 0;
		op = 	6'b000100;
		funct= 	6'b100010;
		zero = 1;  #10;
In reply to VIKRANT97:
I’ve posted the code on EDA Playground at
Edit code - EDA Playground
Just try running the simulation and then look at the state & nextstate signals from the ‘md’ module using EPWave.
The signals are changing value as expected
Yes, it works correctly on the website you posted. However, the same code doesn’t work for me. Why is that? I’m using Modelsim PE Sudent Edition 10.4a
I just downloaded and installed ModelSim PE 10.4g and the design simulated just fine for me.
[10.4g was as far back as I could go to get the install files]
Try deleting the work library and compiling the design from scratch again.
