class packet;
rand bit [5:0] array [];
rand int i;
rand int prev_i;
constraint size_array {array.size() <10;
array.size != prev_i;}
constraint elements {
foreach (array[i])
array[i] inside {[0:64]}
constraint unique_elements {unique {array[i]};} //to make sure no elements repeat at an instance of randomization
constraint inequality {array.size > 3;}
prev_i = array.size;
endclass: packet
module foreach_constraint;
initial
packet pkt = new;
repeat (5)
pkt.randomize();
$display("\nThe size of the array is %0d",pkt.array.size());
$display("elements of the array = %0p",pkt.array);
The op:
The size of the array is 7
# elements of the array = 31 32 47 7 11 34 23
# The size of the array is 9
# elements of the array = 55 33 59 32 53 25 23 43 41
# The size of the array is 7
# elements of the array = 55 9 25 50 51 28 43
# The size of the array is 8
# elements of the array = 29 37 12 24 6 49 24 42
# The size of the array is 4
# elements of the array = 39 19 1 34
7 is randomized twice. I dont want the size to repeat again. What constraint should I use for that condition?
class packet;
randc int arr_size;
rand int i;
rand int prev_i;
array.size==arr_size;}
foreach (array[i])
//prev_i = array.size;
endclass: packet
initial
packet pkt = new;
repeat (5)
pkt.randomize();
Do not declare loop iterator variables (i) separately outside their loops.
Your original example only makes sure that adjacent size values do not repeat. randc is what you want.
class packet;
randc int size;
constraint size_array {size inside {[4:9]}; array.size == size;}
constraint elements { foreach (array[i])
array[i] inside {[0:64]};
constraint unique_elements {unique {array};}
endclass: packet
packet pkt = new;
initial
repeat (5)
assert(pkt.randomize());
