How to write a constraint in system verilog to generate random elements in an array in descending order?
Regards,
Sravan
Regards,
Sravan
Hi Sravan,
One of the methods to implement this would be to generate the random elements within a range and in the post randomise sort it descending.
Th following x_val constraint should be abl to generate in descending order.
class AC;
rand int unsigned x[];
constraint x_size{x.size == 10;}
constraint x_val{foreach (x[i])
if(i != x.size-1)
x[i]>x[i+1];}
constraint x_v1{foreach (x[i])
x[i] inside {[1:100]};}
