Constraint to randomize elements of an array such that at least one is a multiple of 4
HI All,
I want to write a constraint to randomize an array with the following requirements:
a) Sum of all array elements must be 17
b) Array must have at least one element which is multiple of 4.
c) Size of an array could be random
class c;
  rand bit[7:0] arr[];
  constraint c1_arr_sz { arr.sum() with (int'(item)) == 17;
                        arr.size() inside {[2:10]}; }
  constraint c2_arr_m4 { arr.or() with (item % 4 == 0); }
module m1;
  c obj;
  initial
     obj=new();
     repeat(5)
      obj.randomize();
      $display("array is %p",obj);
Output of the code:
array is ‘{arr:’{'h0, 'h3, 'h0, 'h0, 'h0, 'he, 'h0, 'h0, 'h0}}
array is ‘{arr:’{'h8, 'h8, 'h0, 'h0, 'h0, 'h1}}
array is ‘{arr:’{'h5, 'h7, 'h1, 'h4}}
array is ‘{arr:’{'h4, 'h1, 'h7, 'h3, 'h2}}
array is ‘{arr:’{'h1, 'h0, 'h3, 'h1, 'h0, 'h0, 'hb, 'h0, 'h0, 'h1}}
Multiple of 4, is being satisifed only in 2nd, 3rd and 4th iteration.
But it should be satisfied in 1st and last iteration also, may I know the reason?
How to update the code to get all requirements in all iterations.
Kindly share your opinion
Thank You
In reply to Thirumalesh Kumar:
0 % 4 == 0
Hi Dave, I modified the code to have one element (first elemnt)in array should have value =4.
class c;
  constraint c2_arr_m4 { arr.or() with (0 % 4 == 0); }
module m1;
  c obj;
  initial
     obj=new();
     repeat(5)
      obj.randomize();
Output::
array is ‘{arr:’{'hf, 'h2, 'h0} }
array is ‘{arr:’{'hc, 'h4, 'h1, 'h0} }
array is ‘{arr:’{'h2, 'h7, 'h6, 'h1, 'h0, 'h1, 'h0} }
array is ‘{arr:’{'h0, 'h1, 'h7, 'h0, 'h3, 'h6, 'h0, 'h0} }
array is ‘{arr:’{'h0, 'ha, 'h7} }
Please let me know if there is a issue in my code.
Please format your code making your code easier for others to read. I have done that for you.
I believe the original poster was expecting “a multiple of 4” to be a “non-zero multiple of 4”. So the constraint for that would be
constraint c2_arr_m4 { arr.or() with (item > 0 && item % 4 == 0); }
What’s the use of arr.or here?
Give you “at least one” condition. You could also use a slightly more complex sum();
constraint c2_arr_m4 { arr.sum() with (int'(item > 0 && item % 4 == 0)) > 0; }
foreach(arr[i]) {
     if(arr[i] !=0)
          (arr[i] % 4 == 0) -> 1 inside {1};
@Shashank_c03, what is the purpose of your post–it would have no effect as a constraint. (it is unconstrained)
I have a doubt on how to write below constraint using sum and or methods.
  1. Array size between 4:10;
  2. Sum of array elements = 17.
  3. 2 elements in an array should be multiple of 4 and remaining elements can be any value.
 class simple;
       rand bit[4:0] arr[];
       constraint c_values{
           arr.size() inside {[4:10]};
           arr.sum() with(int'(item)) == 17;
      constraint c_divide_4{
           arr.or() with(int'(item >0 && item%4 ==0)) ==2;
    simple s = new();
    s.randomize();
    $display("arr values = %0p", s.arr);
Results::
Seeing constraint solver issue for this code.
Usee arr.sum() instead of arr.or().
Thanks Dave.
Modified the constraint as below and it’s working.
  arr.sum() with(int'(item >0 && item%4 ==0)) ==2;
Note:: In what conditions should we use arr.or() function?
When you want logical OR reduction of elements.
Could you share the material to understand array methods completely?
I was trying to write a constraints using array method , but getting stuck?
