Constraint the number of ones in an unpacked array
If I have a packet that has:
class my_packet;
rand bit vector[31];
constraint c{....}
How do I write a constraint to limit the total number of ones for vector array to a certain range?
I tried to use vector.sum() > 8; vector.sum() <15; but the randomize() function fails to randomize for this.
Is this because sum() would only return a 1 bit answer to the constraint solver i.e 0 or 1?
In reply to shahid31091:
You are correct why it does not give the answer you want. Use
vector.sum() with (int'(item))
