Hello,
I’m running into a constraint solver problem where a “rand” variable shows up as a constant while solving the constraint.
Here is the code I’m using, along with the randomize command.
class base;
rand logic route_to_l1;
rand logic [2:0] srfc_type;
constraint essentials_c {
srfc_type inside {[0:6]};
if (srfc_type inside {1, 4}) {
route_to_l1 == 1;
else {
route_to_l1 == 0;
Randomize statement:
base.randomize with {srfc_type == 0};
Error:
bit[0:0] route_to_l1 = 1’h1;
rand $unit::surftype_t srfc_type; // rand_mode = ON
I’m not able to understand why the var “route_to_l1” gets solved as a constant.
Seems like it solves this variable, before going to “srfc_type”, whereas it should go the other way.
When i write similar code on EDA playground, it seems to work.
range_constraint(1) - EDA Playground
**Question:
- When does a random variable show up as a constant in a solver?
- Is there a limit to the number of variables that can be solved together? The “srfc_type” var is a pivot for a lot of other variables in the class**
In reply to Prathamesh Shinde:
Using if/else in a constraint is effectively two implications.
srfc_type inside {1, 4} -> route_to_l1 == 1;
!(srfc_type inside {1, 4}) -> route_to_l1 == 0;
Since you are constraining
srfc_type to be 0 using the with clause, then
route_to_l1 must also be 0 according to the second implication.
Dave,
I understand that. I expect that once I do a ‘randomize with srfc_type==0’ , then automatically route_to_l1 should become 0. (which is what you’re saying and that is the acceptable solution to me)
The constraint solver somehow starts with route_to_l1==1 and then cannot satisfy the with clause and fails with a “constraint error”
Also, I added another question to the original post.
2. Is there a limit to the number of variables that can be solved together? The “srfc_type” var is a pivot for a lot of other variables in the class
There might be a practical limit to the number of simultaneous random variables, but there is no restriction in the LRM. I think a tool would tell you that you hit a limit before reporting a constraint conflict, which is what you probably have. You’ll need to look at your tool’s User Manual for tips on how to debug constraint conflicts.
