i am trying to apply constraint on randc variable(value between 3 and 9) as used in code shown below. I have understanding that b_var should generate the cyclic values between 3 and 9. but with three calls of randomization it generates 4,8,6.
Then My question is that:
Applying a constraint on randc variable convertes this to normal rand variable?
class A ;
rand int a;
randc bit [3:0] b_var;
constraint cyc_check;
constraint A::cyc_check {b_var>3;
b_var<9;}
initial
A a1;
a1=new;
assert(a1.randomize());
$display ("value of b_var=%d", a1.b_var);
############### OUTPUT ################
run -all;
# KERNEL: value of b_var= 4
# KERNEL: value of b_var= 8
# KERNEL: value of b_var= 6
# KERNEL: Simulation has finished. There are no more test vectors to simulate.
exit
