Let’s assume there’s a 2d pixel matrix 1920 x 1080 in size. I want to constrain the matrix such that in the neighborhood of an off pixel(0) there are only ON pixels(1-255). The pattern should be something like this, for a smaller 5x4 matrix:
x x x x
x 0 x 0
x x x x
x 0 x 0
x x x x
What would be a better way to solve this constraint, assuming I don’t use the foreach loop something as described below:
foreach(mat[i][j]){
mat[i][i] = 0;
foreach(mat[i][j]){
if(mat[i][j] == 0) begin
mat[i-1][j] = $urandom_range(1,255);
mat[i][j-1] = $urandom_range(1,255);
mat[i-1][j-1] = $urandom_range(1,255);
..etc
Can we use the reduction operations somehow for the problem
In reply to sparsh.gupta:
I think the best approach would be to constrain zero elements not to be adjacent.
constraint not_neighbor { foreach (mat[i][j]) {
i>0 && j>0 -> mat[i][j] || mat[i-1][j-1];
i>0 -> mat[i][j] || mat[i-1][j];
i>0 && j< $size(mat,2)-1 -> mat[i][j] != { mat[i-1][j+1];
... // I'll let you fill this in. You need one line for each side and corner
i<$size(mat,1)-1 && j< $size(mat,2)-1 -> mat[i][j] != { mat[i+1][j+1];
Hi Dave, does arr and mat refer to the same two dimensional array? Please clarify. If not then what does two dimensional variable arr needed for?
In reply to srshan_rocks:
another solution can be as follows:
module abc;
class pixel;
rand bit a [3][3];
constraint c1 {
foreach(a[i,j]){
if(j>0) a[i][j] == 0 -> a[i][j-1] == 1;
if(j<3) a[i][j] == 0 -> a[i][j+1] == 1;
if(i>0) a[i][j] == 0 -> a[i-1][j] == 1;
if(i<3) a[i][j] == 0 -> a[i+1][j] == 1;
if(i > 0 && j > 0) a[i][j] == 0 -> a[i-1][j-1] == 1;
if(i < 3 && j < 3) a[i][j] == 0 -> a[i+1][j+1] == 1;
if(i < 3 && j > 0) a[i][j] == 0 -> a[i+1][j-1] == 1;
if(i > 0 && j < 3) a[i][j] == 0 -> a[i-1][j+1] == 1;
pixel p1 = new();
p1.randomize();
foreach(p1.a[i]) begin
$display(p1.a[i]);
I think those were typos/copy/paste errors. fixed.
