Hello all,
I have a matrix that I am trying to put constraints on
my conditions are:
- for each row, # of 1’s is >=1;
- for each column, # of 1’s = 1;
I did:
bit [X-1][Y-1] matrix;
constraint matrix{
foreach(matrix[i]){
$countones(matrix[i])>=1;
//Here I need a foreach to loop through the columns and make sure the countones ==1, I'm
//just not sure of the correct syntax to use.
Thank you!
Hello, that solution does not work in my case since I am using a packed array. Is there any other solution you can suggest?
In reply to Fa300:
You can still use that solution by creating another unpacked array, and setting the following constraint;
rand bit [X-1:0][Y-1:0] packed_matrix;
rand bit unpacked_matrix[X][Y];
constraint matrix_equivalent {
foreach(unpacked_matrix[x,y]) unpacked_matrix[x][y] == packed_matrix[x][y];
constraint matrix_col {
foreach (unpacked_matrix[,j]) unpacked_matrix.sum() with (int'(unpacked_matrix[item.index][j])) == 1;
Hello Dave!
What is with the ,j in the foreach loop? How does it work?
Thanks!
In reply to Shashank Gurijala:
j iterates from 0 to Y-1.
Then why not use just j instead of ,j in the foreach loop?
Because then j iterates from 0 to X-1.
