What is the solution space for the following union?
typedef enum logic[1:0]{SMALL_SIZE=0, MEDIUM=1, BIG=2} size_t;
typedef enum logic[1:0]{SMALL=0,LARGE=3} size_1_t;
typedef union packed {
size_t size;
size_1_t size_1;
logic[1:0] bit_val;
} sample_union;
Constraining size_1 to value LARGE results in constraint solver error
Solver failed when solving following set of constraints
rand bit[1:0] s1; // rand_mode = ON
constraint INTERNAL_0 // (constraint_mode = ON)
((s1 inside {2’h0, 2’h3}) && (s1 inside {[2’h0:2’h2]}));
constraint WITH_CONSTRAINT // (from this) (constraint_mode = ON) (testbench.sv:58)
(s1 == my_package::size_1_t::LARGE);
How can I get the constraint to work and why is the internal constraint ANDing the two enums?
Full code is below
package my_package;
size_t size;
size_1_t size_1;
logic[1:0] bit_val;
} sample_union;
class Base;
// Properties
rand bit test_result;
rand sample_union s1;
endpackage
module GRG_constraint;
import my_package::*;
Base B_h;
bit result;
B_h = new;
if(B_h.randomize() with {
s1.size_1 == LARGE;
$display("B_h.s1.size_1 = %0s",B_h.s1.size_1.name());
$error("Failed to randomize Base");
#10;
In reply to prang:
This is one of the clarifications made to the recent 1800-2017 LRM. The solver is not allowed to choose a value that lies outside the set of named values of the enum type. This is something constraint solvers were already doing, just not documented.
In your union, 0 is the only value common to the two enum types.
I’m not sure what you are trying to accomplish with the packed union; there might be alternatives like created lists of values with queues or associative arrays.
The packed union containing enums is part of an interface struct, we ran into this issue while randomizing input values.
I looked at 2017 LRM and found this section. Is this the clarification you referred to?
If a rand variable of packed structure or packed untagged union type has a member of enum type,
the rules in 18.3 restricting the random values of an enum variable shall not apply to that member.
For example:
typedef enum bit [1:0] { A=2'b00, B=2'b11 } ab_e;
typedef struct packed {
ab_e ValidAB;
} VStructEnum;
ab_e ValidAB;
} VUnionEnum;
When randomizing a variable of type ab_e, the solver can only select a random value of 2’b00 or
2’b11 (A or B, respectively). However, when randomizing a variable of type VStructEnum or
VUnionEnum, the solver can select 2’b00, 2’b01, 2’b10 or 2’b11.
To me, this implies my standalone testcase should work. If I extend the definition of VUnionEnum as follows
typedef enum bit [1:0] { C=2'b01, D=2'b10 } cd_e;
ab_e ValidAB;
cd_e ValidCD;
} VUnionEnum;
when randomizing ValidCD, I have values b01 and b10 available. While randomizing ValidAB, I have values b00 and b11 available. While Randomizing VUnionEnum, I have all 4 values available. Is this right?
In reply to prang:
Sorry I missed the “packed” in your union declaration. This is yet another clarification in the LRM that many not be implemented in your tool. Please contact your tool vendor.
