I have a dynamic array of objects. Each object has an enum variable, let’s call it instruction, values can be ADD, SUB, MUL, DIV for example. When trying to randomize the transaction which includes the dynamic array, i want to constraint the number of objects that has instruction set to ADD.
Pseudo code looks something like this:
class c;
rand enum (ADD, SUB, MUL, DIV) e;
class txn;
rand c c_inst;
constraint add_less_than_5 {(c_inst.find with (item.e == ADD)) <= 5)}
The result of all the equality/relational/logical operators are all 1-bit 1’b1 or 1’b0. The result of the sum() method has the same type as each element.
class c;
rand enum {ADD, SUB, MUL, DIV} e;
class txn;
rand c c_inst[];
function void pre_randomize();
for(int i=0;i<10;i++)begin
c_inst[i]= new();
c_inst[i].randomize();
constraint add_less_than_5 {c_inst.sum() with (int'(item.e == c::ADD)) == 5;}
module abc;
txn t1;
t1=new();
repeat(10) begin
assert(t1.randomize());
$display("%p",t1);
but getting this
# ** Error: (vsim-7100) Invalid call to class::randomize() via a null class reference.
# Time: 0 ns Iteration: 0 Process: /abc/#INITIAL#24 File: testbench.sv Line: 13
c_inst = new[10]; // 10 elements at default value 'null'
foreach(c_inst[i])
c_inst[i]= new();
c_inst[i].randomize(); // Not Needed !!
