Confusion with disable fork?
class fork_join_task;
  task fork_join_wait(int random_time);
    fork: fork_1
       #random_time;
       $display("process1 %t",$time);
        #20;
        $error("Process 1 not completed at %t",$time);
    join_any
    disable fork_1; //giving label name,kill all process for wenever you call and different time to call
module fork_join;
  fork_join_task c1,c2;
    c1=new();
    c2=new();
      c1.fork_join_wait(10);
      c2.fork_join_wait(30);
    join
 //   #200;
    $display($stime,"\t out side the fork");
 //   $finish;
and I got output
process1 10
10 out side the fork
why can’t I use disable<label_name> instead of disable fork in this code?
In reply to Lokesh402:
Your disable fork_1; occurs after the join_any. There is nothing to disable.
See my updated model
    fork: fork_1
       #random_time;
        #20;
       begin #5 $display("after the #40"); end
       begin #2 $display($stime,"\t inside the fork");
             disable fork_1;
    // join_any
    join: fork_1
    // disable fork_1; //
      // fork_1; //giving label name,kill all process for wenever you call and different time to call
Sim results
# KERNEL:          2	 inside the fork
# KERNEL:          2	 out side the fork
  3. Papers:
It might have helped to explain the results you were expecting versus what you actually see.
disable label; kills any process executing under that label name. At the point you execute the first disable fork_1;, there are 3 active processes to be disabled, and the second disable fork_1 executes with nothing to disable.
disable fork; only kills the children of the process executing the disable command. So if you change to adisable fork; only 1 process forked by the c2.fork_join_wait(10) gets killed. The other process forked by the c1.fork_join_wait(30) will get to the #20 $error message.
Hi Dev,
Sorry i asked wrong way, actual doubt is
I have two objects(c1,c2) and one of object(c1) is called disable fork_1(label),but it’s disable fork join_any(fork_1) in all objects. why it’s disabled all the objects(disable fork_1 in c2)?
From LRM::
9.6.3 Disable fork statement
The disable construct terminates a process when applied to the named block or statement being executed by the process. The disable fork statement differs from disable in that disable fork considers the dynamic parent-child relationship of the processes, whereas disable uses the static, syntactical information of the disabled block. Thus, disable shall end all processes executing a particular block, whether the processes were forked by the calling thread or not, while disable fork shall end only the processes that were spawned by the calling thread.
