In my testbench, all the agent sequences are started from a virtual sequence. Therefore if I use this code from the cookbook example:
scope_name = get_full_name(); // this is { sequencer.get_full_name() , get_name() }
Instead of getting “env.agent.sequencer.sequence_name”, I get “vseq.sequence_name” (where “vseq” is the virtual sequence).
Am I doing something wrong here? What would be the preferred way to set configuration for a sequence running on a specific agent for this case? The best solution I have thought of is to pass the m_sequencer to the uvm_config_db#()::get call instead of using get_full_name, but then I can’t set a different config for different sequences.
You are executing the get_full_name() on a sequence. And this Returns you as scope a sequence path.
But I do not understand why you are using this complicated construct.
I’m using in the virtual sequence references to the Agent sequencers like this:
class example_top_base_seq extends uvm_sequence #(uvm_sequence_item);
`uvm_object_utils(example_top_base_seq)
example_top_config cfg;
apb_sequencer apb_sequencer_i;
spi_sequencer spi_sequencer_i;
extern function new(string name = "example_top_base_seq");
extern task body();
// constraints
endclass : example_top_base_seq
This is in the base class. In the actual sequence I have the references of the corresponding sequences like this:
class example_top_default_seq extends example_top_base_seq;
`uvm_object_utils(example_top_default_seq)
// UVC sequences
apb_default_seq apb_seq;
spi_default_seq spi_seq;
extern function new(string name = "example_top_default_seq");
extern task body();
endclass : example_top_default_seq
In reply to miketrim:
Doing this you have to use the p_sequencer concept, because the sequence has no Position in the testbench hierarchy. This Looks like this:
Don’t use p_sequencer because that method requires you to define a sequencer and also makes the sequence dependent on a specific type of sequencer, limiting portability.
Then, you can set different config for different sequences based on their name.
I found a cookbook article mentioning the way cgales suggested. ResourceAccessForSequences
But it doesn’t say anything about the case of a virtual sequence usage. The cookbook should be updated.
By the way, should get_sequencer() be used instead of m_sequencer?
That is, adding its name to its parrent sequence’s path name. In top sequence, adding its name to its sequencer’s path name. Therefore, no sequencer’s path name is gotten if a virtual sequencer with null sequencer is used as a top sequence.
Since each sequence is agnostic to top sequence, get_full_name() should never be used in sequeces. get_sequencer() and get_name() should be used instead. The cookbook should be modified.
I found another function, get_sequence_path(). This function returns the path name of a sequence from top sequence. This is better than get_name(). So, the description should be like the following.
