Could you please let me know, if I write a particular logic using concurrent way or in sequential way , which will be execute faster/slower . ? Which has advantage over the other ?
Here we have 2 events
- Increment a counter
- Display the value of the counter.
Example code snippets for the requirements :
Code1:
forever (@posedge clk) begin
if (en) begin
count = count +1;
display("new count value")
join_none
VS:
Code2:
Now lets assume the count is incrementing in some other parallel block, to display the value of count we are using a parallel thread like below .
forever@(posedge clk) begin
if (en) begin
count = count +1;
join_none
forever @count
join_none
Which among the 2 codes will make the simulator run faster ? if so why. Actual case I have is much more complex, but I just tried to illustrate my problem with this basic code.
