Clocking event in Concurrent Assertions
Hi All,
Generally, the clocking event of concurrent assertion is actually a clock signal
property sva1;
 @(posedge clk) <property_expression1>;
In rare cases where I want to check for FSM state transition one could use ps_state as the clocking event which would trigger sva2 only when state changes.
property sva2;
 @(ps_state) <property_expression2>;
From LRM perspective the above code is perfectly legal
On comparing the above two properties my understanding is that using @(posedge clk) the property would execute numerous times in a simulation even when there is no transition in ps_state.
Such unnecessary attempts are avoided in sva2 which I feel could be possibly better from a tool perspective
I was specifically looking to hear from people with hands-on experience using formal tools whether the sva2 is legal in a formal testbench ?
Are there any disadvantages with using ps_state as a clocking event of a concurrent assertion ?
Regards,
AGS
The problem is when your <property_expression> contains a reference to ps_state. Because of sampling semantics, it will have the old state, not the new state.
You could put your assertion into an implication
$changed(ps_state) |-> <property_expression> ;
Yes, when using ps_state as clocking event I call a subroutine to return the new ps_state and use it as part of property_expression
From SV LRM perspective above logic works as per intention.
I was curious whether it would work / considered legal for formal tb as well
