Is there a way to get the clock period in absolute time (i meain in terms of seconds)?
For example I have a realtime 6.4ns clock period (and timeunit is 1ns). Ho can I get this value in seconds?
Alessandro
Alessandro
In reply to alexkidd84:
6.4ns/1s will give you a real number in seconds.
I meant that I have stored the clock period value in a realtime variable, how can I get that value in terms of seconds (let’s suppose I don’t know the timeunit value…)?
Show me how you calculated the clock period. There’s nothing special about a realtime variable; it’s just a real variable. And how can I suppose you don’t know the clock period if you already told me?
for example:
timeunit 1ns
timeprecision 1ps
clk_period = 3.2ns
how can I get the value 0.0000000032 sec?
I thought that I can obtain this value by dividing clk_period per timeunit, but timeunit is a systemverilog directive…
In fact if I make clk_period/1ns and timeunit changes this formula is not more correct.
You can do
parameter real one_sec = 1s;
real clk_period, clk_period__sec;
clk_period = 3.2ns;
clk_period__sec = clk_period/one_sec;
how you calcuate clk period in your code? if its not constant then you can define timeunit and timeprecision inside class , so that it wont change for that class or pkg.
class test_class;
timeunit 1ns;
function real get_clk_in_sec();
//add dave_59 code here.
return clk_period__sec;
endfunction : get_clk_in_sec
