I am trying to understand clock inference for an unclocked sequence ‘seq’ used as event control @( seq ).
Here are 2 examples which I tried ::
(A) edalink1
(B) edalink2
Regarding (A) ::
[Q1] ‘seq’ matches at T:15, as a result @(seq) unblocks.
Why is that always isn’t triggered/unblocked at T:15 ?
LRM Figure 4-1—Event scheduling regions shows a loopback from observed region to active region. Unblocking of @(seq) is an example of it.
My understanding is that always@(posedge clk1) unrolls to ::
@(posedge clk1);
$display("T:%0t always@(posedge clk1) unblocks",$time);
@(seq);
$display("T:%0t seq matches",$time);
@(posedge clk1);
@(seq);
@(posedge clk1);
@(seq);
[Q2] In absence of default clocking block ( i.e by passing +define+NO_CB ), why doesn’t ‘seq’ inherit the clock ‘clk1’ from always block ?
Why is it that a concurrent assertion embedded within always block can inherit the clock ( Eg: EDA_Unclocked_SVA ) but @(seq) can’t ?
Regarding (B) ::
My understanding is that similar to a1 from thread, ‘seq’ would infer clocking event as @(posedge clk2)
There are 4 scenarios
(1) +define+TRIGGER +define+SAME
(2) +define+TRIGGER
(3) +define+SAME
(4) No +define passed
[Q3] Is the code for (3) and (4) legal ? i.e using @(seq) in consequent. I observe that 2 tools throw a compilation error
I observe that for (1) and (2) ‘seq’ infers clocking event as @(posedge clk2) , shouldn’t (3) and (4) infer the same clock ?
[Q4] Shouldn’t the output for (1) and (3) match ? Similarly shouldn’t the output for (2) and (4) match ?
