Class handles inside modules
CAN I use class handle and/or get it using uvm_config_db inside the module.I am just trying to access data items of a class.But it is giving compilation error :The following is the code :-
module check_50;
import uvm_pkg::*;
  `include "uvm_macros.svh"
  `include "mc_cgm_ral_sample.sv"
int tn_expected=0 ;
int tp_expected=0 ;
int tn_actual=0;
int tp_actual=0;
int cnt_actual =0;
//bit update_stat=0;
bit checker_on=0;
bit checker_off=0;
bit upd0_stat;
bit h_cycle_done ;
bit cnt_ap;
bit cnt_an;
bit cnt_ep;
bit cnt_en;
int t_on_actual;
int t_on_exp_value;
int t_off_exp_value;
int div_value_mux0;
int div_value_mux1;
int div_value_mux2;
int div_value_mux3;
int div_value_mux4;
int div_value_mux5;
bit checking_at_first=1;
int delay;
bit [255:0]divider_exists;
clk_if clk_if;
ral_block_MC_CGM regmodel;
initial
//  	if(!uvm_config_db#(virtual clk_if)::get(this,"","clk_if",clk_if))
//		`uvm_error("NOVIF","clk_if is unset")
    if (!uvm_config_db#(ral_block_MC_CGM)::get(this,"","regmodel",regmodel))
        `uvm_error("NOregmodel","regmodel is unset")
fork                                                              ////continously looking for the transitions in upd status register
//////////////////////top_thread1
forever
       //upd0_stat = regmodel.MC_CGM_MUX_0_DIV_UPD_STAT.get();
       regmodel.MC_CGM_MUX_0_DIV_UPD_STAT.read(status ,upd0_stat);
      //  $display("upd0_stat = %b and time =%0t" ,upd0_stat,$time);
       @(posedge sif.ipg_clk);
forever
     if(sif.ips_addr == 'h320 && sif.ips_module_en ==1 )      ///getting the values////divider0
                 div_value_mux0 = regmodel.MC_CGM_MUX_0_DC_6.DIV.get();
//////////////////////top_thread2
forever
      //  @(posedge sif.ipg_clk);
                        @(negedge upd0_stat )
                               checker_on = 1;      //////upd_stat transition from 1-> 0 has occured now apply the logic
                               checker_off =0;
                               cnt_ap=0;
                               cnt_an=0;
                               cnt_en=0;
                               cnt_ep=0;
                               h_cycle_done=0;
                               $display("Divider configuration has been changed ,upd0_stat = %b and time =%0t and checker_on=%d" ,upd0_stat,$time,checker_on);
      while(checker_on == 1  && checker_off == 0 )
           ////////subthread0
                         while(h_cycle_done==0 && cnt_ap==0)         //collect posedge of ref. clk after upd_stat transition
                           @(posedge vif.o_clk_mux[0])
                           tp_actual =$time;
                           $display("tp_actual =%d " ,tp_actual);
                           cnt_ap=1;
          //////////subthread2
                       while(h_cycle_done==0 && cnt_an==0)             //collect negedge of ref. clk after upd_stat transition
                            @(negedge vif.o_clk_mux[0])
                            tn_actual =$time;
                            $display("tn_actual =%d " ,tn_actual);
                            cnt_an=1;
         ///////////subthread3
                       while(h_cycle_done==0 && cnt_ep==0)              //collect posedge of divided clk after upd_stat transition
                           @(posedge vif.o_clk_mux_div6[0])
                           tp_expected  =$time ;
                           $display("tp_expected  =%d " ,tp_expected);
                           cnt_ep=1;
         ////////////subthread4
                       while(h_cycle_done==0 && cnt_en==0)               //collect negedge of divided clk after upd_stat transition
                          @(negedge vif.o_clk_mux_div6[0])
                          tn_expected  =$time ;
                          $display("tn_expected  =%d " ,tn_expected);
                          cnt_en=1;
        ///////////subthread5
                     wait(cnt_ap==1 && cnt_an==1 && cnt_ep==1 && cnt_en==1 && h_cycle_done==0 )          ////ALL EDGES COLLECTED
                         if(tn_actual>tp_actual)
                            t_on_actual=tn_actual -tp_actual;
                            t_on_actual=tp_actual -tn_actual;
                       if(tn_expected > tp_expected )
                          t_on_exp_value = tn_expected -tp_expected;
                          t_off_exp_value = tp_expected -tn_expected;
                if(tn_expected >  tp_expected )          //CHECKING AT NEGEDGE OF DIVIDED CLOCK
                   if(t_on_exp_value == (div_value_mux0+1)*t_on_actual  )
                       cnt_ap=0;
                       cnt_an=0;
                       cnt_ep=0;
                     //  cnt_en=0;       //commented to store neg_edge
        $display("fail ,t_on_actual=%d,t_on_exp_value=%d, div_value_mux0=%d and the time is %0t",t_on_actual,t_on_exp_value,div_value_mux0,$time);                        `uvm_error("compare","MISMATCH in divider output and reference clock");
                       cnt_ap=0;
                       cnt_an=0;
                       cnt_ep=0;
                     //  cnt_en=0;       //commented to store negedge
               else                               //CHECKING AT POSEDGE OF DIVIDED CLOCK
                     if(t_off_exp_value == (div_value_mux0+1)*t_on_actual   )
                       cnt_ap=0;
                       cnt_an=0;
                   //    cnt_ep=0;       //commented  to store posedge
                       cnt_en=0;
                       cnt_ap=0;
                       cnt_an=0;
                    //   checking_at_first=1;
                       cnt_en=0;
    ////////partial thread(independent of above loop looking for the next upd
               wait(upd0_stat ==1)                ////continuously checking for the next update////if goes high then block the current
                          checker_on =0;
                          checker_off = 1;     //////upd_stat transition from 1-> 0 has occured now apply the logic
                          h_cycle_done=1;
                          $display("upd0_stat = %b and time =%0t and checker_off=%d" ,upd0_stat,$time,checker_off);
      join_any//////////////////////////////end of fork 1
  end  //////////////////////////end of thread 2
join///////////////////////end of fork 2
The compilation error I am getting is expecting keyword endmodule at at the line where fork statement starts. I dont know the exact issue which is preventing it from compilation.
In reply to prashantk:
It is correct what the compiler is saying you. Because there ends the initial block. All your fork/joins have to be in an initial block, there is the content what to do.
Thanks for the prompt reply chr_sue.
I have several other questions :-
1)- As you can see I want to use a class basically ral model inside the dut ,but set get method is not allowing me to do so ,is there any way this can happen.
2.)Can I use the get method to get interfaces inside the module , becasue this is also not allowing me to get interface , we used to do inside classes.
Before answering your question, please use the code tags for SV (on top of the frame the left button).
Both questions are belonging together. Before a get on the config_db can be successful you have to perform a set. I do not see any set.
The get ans set mehodes can be used in the initial block of a module.
