Hi, how can I build a sequence that it is true, only when another sequence has not happened. Let me put an example if I have this sequence:
A B C
(trigger) (seq1) (seq2)
How can I impose that between B and C there isn’t another B in between ?
sequence s_no_set_at_dst(set, set_dst, dst);
##[0:$] set ##0 set_dst != dst;
endsequence
sequence s_no_clr_at_dst(clr, clr_dst, dst);
##[0:$] clr ##0 clr_dst != dst;
endsequence
sequence s_no_set_within_rd(set, set_dst, re, re_dst, dst);
@(posedge clk_i) s_no_set_at_dst(set, set_dst, dst) within ##[0:$] (re ##0 re_dst == dst);
endsequence
sequence s_no_clr_within_rd(clr, clr_dst, re, re_dst, dst);
@(posedge clk_i) s_no_clr_at_dst(clr, clr_dst, dst) within ##[0:$] (re ##0 re_dst == dst);
endsequence
property p_clr_set0_rd (clr, clr_dst, set, set_dst, re, re_dst, out);
logic [5:0] _dst;
@(posedge clk_i) (clr, _dst = clr_dst) |->
##[1:$] (set ##0 set_dst == _dst)
##[1:$] ((re ##0 re_dst == _dst) and s_no_clr_within_rd(clr, clr_dst, re, re_dst, _dst) and s_set_within_rd(set, set_dst, re, re_dst, _dst))
##2 out == 1'b0;
This is the code I have. Which is trying to detect if s_no_set_at_dst or s_no_clr_at_dst occurs while this sequence ##[0:$] (re ##0 re_dst == dst) is “waiting” to happen. But is not working.
