Cannot understand this memory array issue, seems weird, code supplied
Hi, I’m very very new to FPGA programming and I think I’m not understanding something fundemental here as things seem a bit weird. I’m driving a TFT LCD screen and trying to create a Memory mapped display. The code to handle output below is a simplified version which still shows the problem. The variable “DisplayingData” is a 1 bit value that is true if the LCD is currently generating the visible part of the screen (i.e. not the porches etc.)
The screen will show all CYAN by default as can be seen in the !rst_n section. So in the code below this line
if (mem_portB_addr==2'd3)
	lcd_data<=`RED;
and it does, mem_portB_addr has been set to 3 in the reset section so all is good. If I change it to
if (mem[3]==8'h01)
	lcd_data<=`RED;
then again as expected my screen goes all red, as memory location has been set to h01 in the initial section. But then the problem, this code
if (mem[mem_portB_addr]==8'h01)
	lcd_data<=`RED;
does not work, the screen reverts to the default CYAN. I don’t get it. mem_portB_addr=3, mem[3]=8’h01, but the above if statement does not return true.
So, what the heck am I not understanding here, help really appreciated, thank you.
**** The code ****
module lcd_data
	parameter H_DISP = 800,
	parameter V_DISP = 480
	input  wire	 		clk,
	input  wire			rst_n,
	input  wire	[11:0]	lcd_xpos,
	input  wire	[11:0]	lcd_ypos,
	input  wire[18:0]  PixelCount,
	output reg  [23:0]	lcd_data,
    input  wire DisplayingData
    // Define colors RGB--8|8|8 24 bit colours
    `define RED		24'hFF0000
    `define CYAN  	24'h00FFFF
    logic [7:0] mem [0:3];
    logic [1:0] mem_portB_addr;
    reg [7:0] mem_portB_rdata;
        mem[0]=8'h02;
        mem[1]=8'h03;
        mem[2]=8'h07;
        mem[3]=8'h01;
    always@(posedge clk or negedge rst_n)
        if(!rst_n)
            lcd_data = `CYAN;
            mem_portB_addr<=3;
            if(DisplayingData)
                    lcd_data<=`RED;
In reply to sorvad:
Did you try simulation before implementing your FPGA?
This little testcase works for me
  logic clk=0, rst_n=0;
  wire [23:0] lcd_data;
  logic DisplayingData=1;
  lcd_data dut(.*);
  initial repeat(20) #5 clk = ! clk;
    $monitor("%t %h",$time, lcd_data);
    repeat(2) @(negedge clk);
    rst_n = 1;
Hi, Thanks for your reply. No I didn’t try as I’m really new to this and didn’t know how to do test benches etc. I’ll have to look into this as the issue is odd. I’m using Gowin IDE and your code I don’t think will work but I’ll investigate what will. Thanks for your help.
