- I am trying to use display statement in the assertion property, as shown below, but I am getting an error as follows
Errors
Error-[SE] Syntax error
“/vobs/asic_adc_dac_testchip/hydra_t/SE/assertions/hydra_t_strobe_assertions.sv”,
89: token is ‘$display’, column 84
(1, current_time = $time) |=> @(ev_data_delay) ($time - current_time)
$display("\t setup_hold_checker= %d ",($time - current_time) ) >
(SETUP_TIME+HOLD_TIME);
property setup_hold_checker;
time current_time;
@(posedge (clk ^ CK_EDGE_SEL))
disable iff (~resetn || disable_assertion)
(1, current_time = $time) |=> @(ev_data_delay) ($time - current_time) $display("\t **setup_hold_checker**= %d ",($time - current_time) ) > (SETUP_TIME+HOLD_TIME);
endproperty: setup_hold_checker
In reply to venkatasubbarao:
You can, but you have a syntax error. Need a comma ‘,’ before the $display. After you fix that, you have another functional problem.
yes sir you are right i got following error i had tried that before as well ending up with similar error
Error:
89: token is ‘,’, column 80
(1, current_time = $time) |=> @(ev_data_delay) ($time - current_time +
1),$display($stime,"\t setup_hold_checker= %d ",($time - (current_time
+1))) >= (SETUP_TIME+HOLD_TIME);
user49
4
(current_time = $time) |=> @(ev_data_delay)
($time-current_time > (SETUP_TIME+HOLD_TIME,
$display("\t **setup_hold_checker**= %d ",$time-current_time) );
Basically,
(expression, $display(...))
Ben systemverilog.us
