Can we return data from SystemVerilog task?
Hi All,
Can we return data from System verilog task?
Does its possible or any work around?
Mehul
In reply to mehul.gor:
User-defined SV tasks can have output arguments.
A task may have output arguments whose values are assigned upon returning from the task.
If an input argument is a class reference, you can update the class object by reference at any time during the task call.
I am using DPI for interface of C and System verilog.
In C code, i am using below function which return data from given address using READ function.
data = READ(address);
READ function require to be blocking as it perform read operation via system verilog driver.
I have defined READ task in system verilog. But how to return data from this READ task?
In Verilog/SystemVerilog, a potentially time consuming routine must be written as a task.
task READ_DPI(input int address, output int data);
  #100 data = MEM[address];
export "DPI-C" task READ_DPI;
If you compile this code generating a DPI header file, it will produce this prototype:
DPI_LINK_DECL int
READ_DPI(
    int address,
    int* data);
An output argument is passed by reference in C. Note that the int return value of a DPI exported task is used for disables, and can be ignored if not used.
Your code can call this routine as:
#include "dpi.h"
READ_DPI(address,&data);
If you really need the READ routine to be a function in C, you can put a wrapper around it:
int READ(
  int address) {
  int data;
  READ_DPI(address &data);
  return data;
It Works! Thanks Dave.
