Can we initialize a member of class by passing a value in new function as below.
I could access with object but i want to see variable a can be initialized as in code
program main;
class baseclass;
int a;
task display;
$display("a=%d",a);
endtask:display
endclass:baseclass
baseclass b;
b=new(10);
//b.a=10;
b.display();
endprogram:main
class baseclass;
int a;
function new(int _a);
a = _a;
task display;
$display("a=%d",a);
endtask:display
endclass:baseclass
However, I would not recommend doing it this way as this creates a number a problems later on. If you start adding more arguments to the constructor, you have to change your code everywhere the class is constructed. The UVM factory does not allow this anyways.
As with any function or task, if you start changing the formal arguments of a routine, then you either need to provide proper defaults, or you must change the actual arguments everywhere the routine is called. A constructor is no different.
The UVM factory provides a create() method that you use instead of calling the constructor new() directly. It only passes along one constructor argument, name for uvm_objects, plus a parent argument for uvm_components.
