suppose a method is defined as virtual in base class. using extended class handle/object is it possible to call the virtual method in base class?
In reply to Manoj J:
Yes.
Calling super.virtual_method() calls the previous virtual_method() from class that the current method was extended from. If there are multiple levels of inheritance with multiple virtual_method() overrides, you skip over levels of extension by calling base_class::virtual_method() directly.
Thank you dave!!
