Can we access DUT signals in sequence class
can we access DUT signals in sequence class? if yes then how?
mukesh
In reply to muku_383:
Can you? Yes.
Should you? No. You should only access signals using an agent’s driver or monitor.
In reply to cgales:
as you said,
can i? yes, can you give explanation with example
thanks
You can do this because the UVM does not have compliance rules. But it is useless to do this and it complicates your testbench and the sequence execution.
Hi Muku_383,
Ideally you should not access them from sequence as it kills the reuse feature for next gen Testbench.
But there is a provision.
  1. Set the interface in top.sv with null and scope as ‘*’
  2. get the interface inside the base_sequence body() method using get_full_name() so that seqr path will come
Then you are able to use that wherever necessary.
