Can parallelism be achieved between software & hardware language while using DPI as an interface.
Normally a task call from System verilog to ‘c’ blocks simulation & it proceeds only when the call is returned.
Also in case of a driver integration there is requirement for asynchronous events from hardware as well as data being driven from the driver. Can anyone share info on how these implementation can be done ?
Yes, it’s possible to use the DPI to achieve parallelism in C calling exported tasks to SystemVerilog. However, the notion of time is very different in the HDL and C worlds. See my DVCon paper Easy Steps Towards Virtual Prototyping using the SystemVerilog DPI which discusses some of the issues of tracking time between the two domains.
Thanks for the reply. The document was very useful in understanding the DPI usage.
How do we take a call on whether software or hardware acts as master ?
In case of using IPC channel software acts as a master, but can you elaborate on how IPC channel be used with DPI ?
Hand shaking between hardware and c code is possible using DPI-C.
Suppose you are launching a task from systemverilog which is a C subroutine.
Now from that C subroutine if you are calling some exported task from system verilog then again control will go back to system verilog and hardware will be running until there is a next call for again some C subroutine.
In that way both processes will be running alternatively.
