I’m trying to coneect interface with uvm_config_db set/get in intial block.
But Compiler said that Component does not refer to a scope.
I didn’t get it because I set uvm_config_db at initial begin, why does it say it does not refer to a scope?
uvm_config_db #(virtual i2c_intf)::set(null,"*", "i_i2c_intf", i_i2c_intf);
if (!uvm_config_db #(virtual i2c_intf)::get(null, "", "i_i2c_intf", i_i2c_intf))
`uvm_fatal("FATAL MSG", "Virtual Interface Not Set Properly");
But problem is that I got error about Component name ‘i_i2c_intf’ does not refer to a scope.
QuestaSim-64 vlog 2021.3_1 Compiler 2021.08 Aug 15 2021
Start time: 21:42:23 on Feb 18,2022
vlog -writetoplevels questa.tops -timescale 1ns/1ns "+incdir+/playground_lib/uvm-1.1d/src" -L /usr/share/questa/questasim//uvm-1.1d design.sv testbench.sv
-- Compiling module adder
-- Compiling interface i2c_intf
-- Compiling interface axi_intf
-- Compiling interface ahb_intf
** Note: (vlog-2286) testbench.sv(11): Using implicit +incdir+/usr/share/questa/questasim/uvm-1.1d/../verilog_src/uvm-1.1d/src from import uvm_pkg
-- Compiling package testbench_sv_unit
-- Compiling module test
-- Compiling module tbench_top
-- Importing package /usr/share/questa/questasim//uvm-1.1d.uvm_pkg (uvm-1.1d Built-in)
** Error: testbench.sv(29): Component name 'i_i2c_intf' does not refer to a scope.
** Error: testbench.sv(30): Component name 'i_i2c_intf' does not refer to a scope.
** Error: testbench.sv(31): Component name 'i_i2c_intf' does not refer to a scope.
End time: 21:42:24 on Feb 18,2022, Elapsed time: 0:00:01
Errors: 3, Warnings: 0
Exit code expected: 0, received: 1
this is code from (2) - EDA Playground . for understanding my problem
`include "interface.sv"
`include "test.sv"
module tbench_top;
import uvm_pkg::*; //Add for uvm_config_db
`include "uvm_macros.svh"//Add for uvm_config_db
//creatinng instance of interface
// i2c_intf i_i2c_intf();
axi_intf i_axi_intf();
ahb_intf i_ahb_intf();
test t1(i_i2c_intf, i_axi_intf, i_ahb_intf);
adder DUT (
.a(i_i2c_intf.a),
.b(i_i2c_intf.b),
.c(i_i2c_intf.c),
.a0(i_axi_intf.a0),
.b0(i_axi_intf.b0),
.c0(i_axi_intf.c0),
.a1(i_ahb_intf.a1),
.b1(i_ahb_intf.b1),
.c1(i_ahb_intf.c1)
Would you may guide me how do I get Component name ‘i_i2c_intf’ which is not refer to a scope.?
