I was wondering if it’s legal to have assertion in constant function. I couldn’t find an issue in the LRM but when I compiled the code in one of the three major simulators it says its not supported. I am trying to determine if this is an LRM issue or tool issue. Thanks
Code:
package test_pkg;
function automatic int logb2
input int value
if (value >= 1)
value = value -1;
for (logb2 = 0; value > 0; logb2++)
value = value >> 1;
return(logb2);
assert (value >= 1) else $error("%m logb2 function issue with computation logb2 of %d\n", value);
In reply to noel:
We don’t discuss specific tools is this forum, but your code looks legal SV.
Immediate assertions can be in functions, tasks, and classes. Basically, anywhere an “if” statement is allowed.
1800’2017 “The immediate assertion statement is a test of an expression performed when the statement is executed in the procedural code. The expression is nontemporal and is interpreted the same way as an expression in the condition of a procedural if statement. In other words, if the expression evaluates to X, Z, or 0, then it is
interpreted as being false, and the assertion statement is said to fail. Otherwise, the expression is interpreted as being true, and the assertion statement is said to pass or, equivalently, to succeed."
I was wondering if it’s legal to have assertion in constant function. I couldn’t find an issue in the LRM but when I compiled the code in vcs it says its not supported. I am trying to determine if this is an LRM issue or tool issue. Thanks
Code:
package test_pkg;
input int value
if (value >= 1)
value = value -1;
value = value >> 1;
return(logb2);
endfunction // logb2
endpackage:test_pkg
May be it is something specific to VCS alone ?? I see it working perfectly fine with Cadence simulator…
xcelium> run
xmsim: *E,ASRTST (./testbench.sv,16): (time 2 NS) Assertion test_pkg.logb2.__assert_1 has failed
test_pkg.logb2 logb2 function issue with computation logb2 of 0
Thanks I corrected my original post and removed the name of the simulator. It works with 2 other major simulators. I will need to check synthesis and other tools.
1800’2017::20.8.1 Integer math functions
The system function $clog2 shall return the ceiling of the log base 2 of the argument (the log rounded up to an integer value). The argument can be an integer or an arbitrary sized vector value. The argument shall be treated as an unsigned value, and an argument value of 0 shall produce a result of 0. This system function can be used to compute the minimum address width necessary to address a memory of a given size or the minimum vector width necessary to represent a given number of states.
For example:
integer result;
result = $clog2(n);
I tried it Edit code - EDA Playground
and it seems that some simulators support the $clog2(n) function.
I believe that your error is in the recursive use of the function in your package.
