Calculate and compare multiple clock frequencies if the condition met!
Hey Ben,
I tried to simplified my question to get an idea about the process.
My main requirement is as follow:
module assertions_module (
    input logic signal_1,
    input logic signal_2,
    input logic signal_3,
    input logic signal_4,
    input logic signal_5,
    input logic clka,
    input logic clkb,
    input logic clkc
real clka_freq;
real clkb_freq;
real clkc_freq;
logic clka_t;
logic clkb_t;
logic clkc_t;
task automatic freq_meter(ref logic clk_in, ref real clk_freq);
    time    start_time, end_time;
    time    period;
    @(posedge clk_in);
    start_time = $time;
    @(posedge clk_in);
    end_time = $time;
    period = end_time - start_time;
    clk_freq = real'(1e12/period);
    clk_freq = clk_freq/1e6;
endtask : freq_meter
// I am using following 3 always because when use ref for input of freq_meter it says Variable input ports cannot be driven
    always @(posedge clka)
        clka_t <= clka;
    always @(posedge clkb)
        clkb_t <= clkb;
    always @(posedge clkc)
        clkc_t <= clkc;
    task automatic start_measurement();
        active <= 1;
        repeat(6) begin
            fork
                @(posedge clka_t)
                        freq_meter(clka_t, clka_freq);
                @(posedge clkb_t)
                        freq_meter(clkb_t, clkb_freq);
                @(posedge clkc_t)
                        freq_meter(clkc_t, clkc_freq);
            join
            @(posedge clka_t)
                if(clka_freq == clkc_freq)
                    clka_match = 1;
            @(posedge clkb_t)
                if(clkb_freq == clkc_freq)
                    clkb_match = 1;
        clka_match_assert: assert(clka_match == 1);
        clkb_match_assert: assert(clkb_match == 1);
        clka_match = 0;
        clkb_match = 0;
        active = 0;
    endtask : start_measurement
    always @(posedge clka_t)
        clka_assert1: assert property(
        !active && signal_1 && !signal_2 && signal_3 |-> (1, start_measurement()));
    always @(posedge clkb_t)
        clkb_assert1: assert property(
        !active && signal_4 && !signal_2 && signal_5 |-> (1, start_measurement()));
        clka_assert2: assert property(
        !active && !signal_1 && signal_2 |-> (1, start_measurement()));
        clkb_assert2: assert property(
        !active && !signal_4 && signal_2 |-> (1, start_measurement()));
this |-> (1, start_measurement()) means the task start_measurement() always call regardless of left side of |-> ?
In either case the condition never met and I don’t see the assertion/start_measurement/freq_meter call at all.
