Cache verification
I was wondering what is the best methodology for verifying a cache deep inside the design. Are there any specific methods / methodologies which can ensure that we have verified the cache functionality (reference counting, eviction, invalidation any livelocks etc) fully ?
I wanted to know of any methods other than white box verification.
Thanks in advance,
Madhu
One method is to use a black box approach with assertions written in the SystemVerilog Interface block. I demonstrate this concept in my SystemVerilog Assertions Handbook; thus,
// Example of requirements
//In the event of a cache read miss,
//the read request for the same address must be forwarded to the main memory within five clocks.
// Uding a module for demo:
module cache_mem;
    timeunit 1ns;
    timeprecision 1ns;
    logic clk, cache_mem, cache_miss, main_mem_rd, cache_rd, reset_n;
    int   rd_addr, main_mem_rd_addr;
    property p_cache_miss_2_main_mem_xfer (
        cache_read,                                    // read from cache control
        cache_miss,     // miss control from cache controller
        rd_addr,  // desired data address
        main_mem_rd,  // main memory read control
        main_mem_rd_addr,     // main memory read address
        reset_n);                                    // active low reset
        int v_rd_addr_at_cache; // assertion variable to record and test  the read address
        disable iff (!reset_n)   // abort if reset_n==0
        ((cache_read && cache_miss), v_rd_addr_at_cache =rd_addr) |=>
        ##[0:5] main_mem_rd && (main_mem_rd_addr == v_rd_addr_at_cache);
    endproperty :  p_cache_miss_2_main_mem_xfer
    default clocking @(negedge clk);
    endclocking
    ap_cache_miss_2_main_mem_xfer : assert property  // property instantiation
        (@(posedge clk)  p_cache_miss_2_main_mem_xfer ( cache_rd, cache_miss,
                                     rd_addr,     main_mem_rd, main_mem_rd_addr, reset_n));
endmodule : cache_mem
Another example using assertions
// For example, in a write-back policy-based cache coherency controller,
// once a write request to an address is found in the cache (i.e. a write hit),
// the following sequences of events should occur (possibly at varied time intervals):
// •   The line is marked as “dirty”.
// •   Any other caches having a copy of this address shall mark their copies as invalid.
// •   Eventually, the dirty line shall be cleaned – i.e. modified data shall be written back to main memory.
module cache_wr_hit;
    `define DIRTY 1'b0
    `define INVALIDATE 1'b0
    bit clk, bus_req, ack, cache_hit, wr;
    typedef bit[15:0] data_t;
    bit[9:0] addr_write;
    data_t wr_data;
    data_t[0:1023] cache, remote_cache;
    default clocking cb_clk @ (posedge clk);
    endclocking
    sequence q_wr_hit;
        @ (posedge clk) first_match(wr ##[1:2] cache_hit);
    endsequence : q_wr_hit
    sequence q_invalidate;
        bus_req ##[1:2] ack ##1 remote_cache[addr_write]== `INVALIDATE;
    endsequence : q_invalidate
    ap_wr_hit: assert property(
        q_wr_hit.triggered |=>
            first_match(cache[addr_write] == `DIRTY ##1 q_invalidate
                        ##[1:$] cache[addr_write]==wr_data) |->
                                        remote_cache[addr_write]==wr_data
endmodule : cache_wr_hit
Hi Ben,
Thanks for the response. Could you point me to the book. I would be interested to read further and try out.
Madhu
In reply to mseyunni:
My book is “SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6”
However, the book is more about how to write assertions. and I used several examples and models to explain the concepts.
Ben
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
