Hello,
I have following scenario.
file1
module block();
file2
module Design();
block b();
file 3
program test();
endprogram
file4
module assertion();
file 5
module top();
Design d();
// I want to bind assertion module here to my module block.
how can i bind assertion module to my block module from top module?
module top();
Design d();
bind block assertion instname();
There are many examples of using bind for SystemVerilog assertions around.
Thanks. That works well. but I am having multiple instances of block module inside my Design module. and i want to bind with specific module. so I am using following.
module Top();
Design d();
bind block : b assertion instance name();
above code ends with an error: b is not valid instance name for module block. b must be valid name. Kindly guide me.
Mangal,
You could try:
module Top();
Design d();
bind block : d.b assertion instance name();
Or directly use:
module Top();
Design d();
bind d.b assertion instance name();
We cover this in our SVA book, pp 168- See: http://verifnews.org/publications/books/ if you want to get hold of an Indian edition of this book.
Regards
Srini
http:/www.verifworks.com
