BFM vs Driver
Hi, Can someone tell me what is the difference between driver and BFM.
Is it in SV we call it BFM and in UVM we call it Driver?
In reply to mukul1996:
https://verificationacademy.com/forums/uvm/what-difference-between-driver-and-bfm#reply-53187
[list=1]
[] A BFM is a Bus Functional Model.
Any device has a behavior and it interacts with the outside world thru interfaces or “busses” (of length 1 or more signals for its inputs and outputs.
A BFM reflects the behavior of that device at a level higher than gate level; it could be RTL or even a higher level. As the design progresses, that BFM can be replaced with the actual design. Thus, I can design a BFM for a FIFO, a processor, or even a standard bus interface (e.g., HDMI bus). Those BFMs are used to test your design. For example. if I am designing a cable box ASIC that interfaces with a CPU IP and a HDMI interface I’ll need 2 BFMs, one for the CPU and another one for the HDMI.
]A Driver is the software that drives the BFM. FOr the above example, my chip is exposed to a HDMI and a CPU. Those 2 BFMs respond to my chip and they also send commands to my chip to do things. For example, the CPU may want to command my chip to do X tasks. That command and responses to my chip come my CPU driver. Note the driver is not a just one-way communication because it reacts with the actual design. If the design says, HOLD, NOW GIVE ME MORE, the driver of the BFM has to react accordingly.
/list]
Botom line, they are not the same thing though a BFM has a driver.
  3. Papers:
Thanks @Ben for the explanation.
