I am trying to design and test a dff using the requirement here.
`timescale 1ns/1ps
timeunit 1ns;
timeprecision 1ps;
module register (
input logic clk,
input logic rst_n, // active-low reset
input logic enable,
input logic [7:0] data,
output logic [7:0] out
// Sequential logic with async reset
always_ff @(posedge clk or negedge rst_n) begin
if (!rst_n)
out <= 8'h00; // reset clears output
else if (enable)
out <= data; // load input when enable = 1
out <= out; // hold previous value
// Code your testbench here
// or browse Examples
module register_test;
// DUT signals
logic clk;
logic rst_n;
logic enable;
logic [7:0] data;
logic [7:0] out;
// Instantiate DUT
register dut (
.clk (clk),
.rst_n (rst_n),
.enable (enable),
.data (data),
.out (out)
// Clock generation (10ns period)
clk = 0;
forever #5 clk = ~clk;
// Monitor: display signals automatically
$timeformat(-9, 1, " ns", 10);
$monitor("time=%t enable=%b rst_=%b data=%h out=%h",
$time, enable, rst_n, data, out);
// Task for comparison
task check_register_state;
if (out !== data)
$display("FAIL at %t: expected=%h, got=%h", ($time - 10), data, out);
$display("PASS at %t: out=%h", ($time - 10), out);
// Stimulus
$dumpfile("dump.vcd");
$dumpvars(0, register_test);
// Initialize
// rst_n <= 1; enable <= 'x; data <= 'x; // 0
// #15 rst_n <= 0; expect_test; // 15
// #10 rst_n <= 1; enable <= 0; expect_test; // 25
// #10 enable <= 1; data <= 8'haa; expect_test; // 35
// #10 enable <= 0; data <= 8'h55; expect_test; // 45
// #10 rst_n <= 0; enable <= 'x; data <= 'x; expect_test; // 55
// #10 rst_n <= 1; enable <= 0; expect_test; // 65
// #10 enable <= 1; data <= 8'h55; expect_test; // 75
// #10 enable <= 0; data <= 8'haa; expect_test; // 85
// #10 $display("REGISTER TEST PASSED");
rst_n = 1; enable = 'x; data = 'x; // 0 ns
#15 rst_n = 0; // 15 ns
#10 check_register_state; // 25 ns
rst_n = 1; enable = 0;
#10 check_register_state; // 35 ns
enable = 1; data = 8'haa;
#10 check_register_state; // 45 ns
enable = 0; data = 8'h55;
#10 check_register_state; // 55 ns
rst_n = 0; enable = 'x; data = 'x;
#10 check_register_state; // 65 ns
#10 check_register_state; // 75 ns
enable = 1; data = 8'h55;
#10 check_register_state; // 85 ns
enable = 0; data = 8'haa;
#10 check_register_state; // 95 ns
#1000;
$finish;
and log message I got seems to be true compared to the requirement above.
xcelium> run
time= 0.0 ns enable=x rst_=1 data=xx out=xx
time= 15.0 ns enable=x rst_=0 data=xx out=00
FAIL at 15.0 ns: expected=xx, got=00
time= 25.0 ns enable=0 rst_=1 data=xx out=00
FAIL at 25.0 ns: expected=xx, got=00
time= 35.0 ns enable=1 rst_=1 data=aa out=aa
PASS at 35.0 ns: out=aa
time= 45.0 ns enable=0 rst_=1 data=55 out=aa
FAIL at 45.0 ns: expected=55, got=aa
time= 55.0 ns enable=x rst_=0 data=xx out=00
FAIL at 55.0 ns: expected=xx, got=00
time= 65.0 ns enable=0 rst_=1 data=xx out=00
FAIL at 65.0 ns: expected=xx, got=00
time= 75.0 ns enable=1 rst_=1 data=55 out=55
PASS at 75.0 ns: out=55
time= 85.0 ns enable=0 rst_=1 data=aa out=55
FAIL at 85.0 ns: expected=aa, got=55
My question is that if for example data = out = aa at the same timestep, it is not true according to the behavior of dff because out must be aa at the next cycle as I understand. Is this requirement true ?
