hi,
I am having questions about how automatic variables work in fork statement in for loop. Referring to the code below, the simulator (VCS) is displaying 0,1,2 for program test (case1) however, for all other programs (test1-test3), it is displaying 3,3,3 though variable k is automatic in all cases. Can someone help me and explain this behaviour?
module automatic test;
for (int j = 0; j < 3; j++)
fork //begin
automatic int k = j;
// k = j;
$write (k);
//end
join_none
#0 $display ("\n test");
module automatic test1;
fork begin
// k = j;
$write (k);
join_none
#0 $display ("\n test1");
module automatic test2;
fork begin
k = j;
$write (k);
join_none
#0 $display ("\n test2");
module automatic test3;
fork //begin
k = j;
$write (k);
//end
join_none
#0 $display ("\n test3");
The thing to know here is that automatic variables have a lifetime based on an activation scope. They are created and initialized when entering that scope, and disappear when leaving that scope. The key thing to know is the a scope remains active until reaching the procedural end of that scope, or after all child process have completed, whichever comes last.
Cases 2 and 3 are essentially the same. The activation scope for k is the begin/end block inside the fork/join_none. There are actually 3 activations of k, one for each process forked off. None of those processes activate until after the parent initial process reaches the #0 delay, which is after the for-loop has reached its final value j==3. The only difference with case 3 is you initialize each of the kâs to 3 as in case 2, but then the first statement of the process is to assign it to 3 again. The variable k disappears when each process terminates.
In cases 1 and 4, the activation scope for k is entering the fork/join_none. As with cases 2 and 3, there will be 3 activations of k, but this time the activation starts immediately with each iteration of the for-loop. So k gets initialized with the current value of j; 0, 1, and 2. The lifetime of each k continues until the process spawn by the fork/join_none terminates.
The problem with case 4 is there are two processes spawned by each activation of the fork/join_none: the assignment k = j, and the $write(k). The assignment to each k will take the final value of j==3 since the process does not start until the initial process reaches the #0 delay. But now you have a race condition with the process with the $write(k) statement. If the write executes first, you will see the same results as case 1: the values 1, 2, and 3. But if the assignment statement executes first, k gets the final value of j==3, and you get the same results as case 3.
thanks a lot for the explanation. It is clear now. I have a related question:
If I move the automatic variable declaration and initialization outside fork statement, as given below:
case 5:
program automatic test4;
for (int j = 0; j < 3; j++) begin
fork //begin
// k = j;
$write (k);
//end
join_none
endprogram
Then the result it displays is 2 2 2 (since the final value of k after the for loop completes will be 2, which will be used by $write (k)). However, in the Chris Spear book (system verilog for verification, second edition) on page 226/227, it says case 1 and case 5 should give same result. This is confusing. Can you please comment on this.
BTW, please use code tags to format your code. I have done that for you in your post.
Yes, case 1 and 5 should work the same. The only difference would be visibility of the variable k after the fork statement if there were other statements. Your code works fine for me in ModelSim/Questa. It prints 2 1 0. (any order would be correct).
Also, I do not recommend the use of program blocks. Just use a module.
I have run this code (test4)on the VCS simulator and but it prints 2, 2, 2.
Now based on the explanation you have given earlier, the activation scope for k (in program test4) is the beginâŚend block of for loop. So k will get values 0,1,2 and these values will be used by $write(k) and it should print 0,1,2. This is unlike cases 2 and 3 above where k is activated in begin end block inside fork, which gets scheduled after #0 delay and by that time j would have reached 3. So it uses j ==3 for all 3 processes and prints 3,3,3 (let me know if this understanding is correct).
I am not clear why VCS is giving different result. I have tried replacing program with module statement, but it makes no difference.
Also you have said âThe only difference would be visibility of the variable k after the fork statement if there were other statements.â in your comment. Can you please elaborate on this.
HI Dave,
I have one more question on automatic variables:
System verilog LRM 3.1 says âIn a data_declaration that is not within the procedural context, it shall be illegal to use the automatic keywordâ. Does it mean that automatic variables can be declared only in procedural blocks and any variable not within procedural block is static by default?
I understand procedural blocks are - initial, always,final, beginâŚend, forkâŚjoin, always_comb, always_latch, always_ff, task, function etc.
Are there any more of them?
rgs,
-sunil
Yes, automatic variables can only be declared in a procedural block - those are the only blocks that have a potential lifetime shorter than the entire simulation.
So, I have a related question, primarily out of curiosity as I solved my issue. I had code similar to case 1 above that worked fine in a test class; however, the comp errored out in a task declared in the base test class - didnât like the automatic int declaration. HOWEVER, I then realized that the fork in my test class was named so I added a name to the base test class task version. Bingo, compiles - weâll see if it runs. Why does naming the fork fix the compile problem?
Well, this is a never mind, I went back to reproduce the error and FAILED. Must have been an env or moldy/corrupt build issue. This is a good thread to jog my memory about this issue tho, itâs pretty easy to get bitten by it. In fact, I got the original attempt to work in my test because I âforgotâ to put a begin after the fork as I had intended.
When you say âNone of those processes activate until after the parent initial process reaches the #0 delayâ for case 2 and 3, what is the reason for that? Does not all forked processes execute at zero time and the #0 delay line run at in the end?
Because the LRM says so. To keep things more deterministic, section 9.3.2 Parallel blocks says the processes do not start until the parent process suspends or terminates.
Hi Dave, with regard to fork join_none, I have gone through some threads asked in the forum but I still donât understand why in this code j = 0 is not getting printed. Would you please help me understand this?
for (int j=0; j<3; j++) begin
#1;
$display($time, " j = %0d",j);
join_none
This happens because the process inside the fork/join_none (the $display) does not start until the parent process suspends or terminates.
The first process does not start until the second iteration suspends at the #1.
The second process does not start until the third iteration suspends at the #1.
The third process does not start until exiting the loop and reaching the end of the initial.
In all three cases j has already advanced by +1. This is why we always recommend creating a separate automatic variable that has the loop iterator value at the point when the process gets scheduled, not when it starts executing.
